Author Topic: Help: Asteroid Deluxe. Stopped working after I opened the door  (Read 2553 times)
Jetto Funk
  • Last login:April 09, 2013, 03:10:28 pm
  • Moo
« on: September 06, 2007, 04:08:41 pm »
So I blew a fuse in my cab a while back. Well I just got unlazy today and fixed the fuse and was playing with the cab for a good portion of the day. Well I opened the coin door and the machine shut off. No big deal I thought, there's the on off switch that is held by the door. I cleaned up the machine a bit than shut the door and went to turn it on and nothing.. Not even a sound or a pop. I checked all the fuses and they look fine, I'm stumped. I pressed the button manually and tried to reset it a few times but nothing.
Any ideas?
Ed_McCarron
Re: Help: Asteroid Deluxe. Stopped working after I opened the door
« Reply #1 on: September 06, 2007, 04:12:32 pm »
Switch died?  Try bypassing it?
Havok
  • Trade Count: (+17)
« Reply #2 on: September 06, 2007, 04:19:52 pm »
Check the slam switch and verify the contacts aren't touching? (If Asteroids has one)
Jetto Funk
  • Moo
« Reply #3 on: September 06, 2007, 04:22:19 pm »
Hmm, just cut the wires and spin them together?
Not really a slam switch but same principal
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: September 06, 2007, 04:26:19 pm »
They look fine or they test fine. You can't trust a visual inspection.
Have you tried pulling the interlock switch out (e.g. open the door and pull the plunger instead of pushing it) ?
Working: Not Enough
Projects: Too Many
Progress: None
Ken Layton
  • Guru
  • Technician
« Reply #5 on: September 06, 2007, 05:13:03 pm »
Stroids Deluxe has TWO white safety interlock switches wired in series with each other. Opening either one kills all power to the machine. One is located by the coin door hinge (operated by the coin door being closed) and the other is located at the back door of the cabinet (operated by the back door being closed).
Let me say this again:
Both switches must be activated at the same time or the machine will not get power.
Jetto Funk
  • Moo
« Reply #6 on: September 06, 2007, 06:15:30 pm »
the back one is pre rigged already, doesn't need to have the back on to work. I'll rig the front one like that too. I haven't tested them, I'll get on that tonight
Kevin Mullins
    • Me on Myspace
« Reply #7 on: September 06, 2007, 06:49:35 pm »
You shouldn't have to "rig" anything..... PULL the switch OUT as mentioned earler and see if the machine works. (check both switches)
Does the marquee and blacklight come on?
Jetto Funk
  • Moo
« Reply #8 on: September 06, 2007, 10:05:14 pm »
the marquee never turned on, didn't realize there was a backlight
Jetto Funk
  • Moo
« Reply #9 on: September 07, 2007, 09:04:43 am »
Tried pulling the switched and wiring them up together as well, nada...
I replaced the fuses and nada as well.
What else could it be?
Let's recap:
Machine was on and doing it's thing.
I opened coin door and machine turns off.
I close coin door and machine stays off.
Check:
Fuses
Switches
Stumped :\
CheffoJeffo
« Reply #10 on: September 07, 2007, 09:10:30 am »
So the primary symptom is absolutely no power to the cab at all (no power to marquee, blacklight, monitor, etc.) ?
Do you have a multimeter ?
Working: Not Enough
Projects: Too Many
Progress: None
Jetto Funk
  • Moo
« Reply #11 on: September 07, 2007, 09:47:17 am »
Fixed it, it was a little bit of everything.
The button had a short in it that was causing the fuses to blow. Fixed the wiring and fixed the fuses, all is well now  :cheers:
Thanks for the help guys!
Now time to fix Tron, Mace and the Mame machine
BrentRadio
  • Last login:March 11, 2021, 06:26:04 am
  • Stop by for a game and a beer!
    • Jack Daniel's Barcade!
« Reply #12 on: September 07, 2007, 11:53:08 pm »
Don't forget to get the Asteroids Multikit when it comes out.
http://www.brasington.org/arcade/adl/
Brent
