Author Topic: mala and project 64  (Read 4678 times)
philby85
  • Last login:August 28, 2008, 08:25:17 pm
mala and project 64
« on: September 03, 2007, 10:51:31 pm »
Hi Guys,
Got mala setup with mame and project 64 all works ok. I am not sure how to exit out of project 64 back to the rom list in mala. In mame it's esc but esc in project 64 is change to a window is there a setting in project 64 or mala? Sorry for the dumb question in advance  :P
cheers
Philby
philby85
Re: mala and project 64
« Reply #1 on: September 03, 2007, 11:17:07 pm »
Doh! solved it found a setting in mala! Good on ya Swindus!
philby
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #2 on: September 04, 2007, 12:03:35 am »
You don't actually have to use Mala's brute force method to close Project64.  There are keyboard settings in the options of  Project64 to change the ESC key to exit the program which means Project64 will close more gracefully.  Seems like you must first remove it from its default task in Project64 before adding it to the Exit task.  I'm using the beta version of Project64.
philby85
« Reply #3 on: September 04, 2007, 01:14:28 am »
Thanks SGT  :applaud:
Have you used a ps3 controller with project64?
philby
SGT
« Reply #4 on: September 04, 2007, 01:31:22 am »
No, the only console controller I have tried is a PS2 look-alike.
philby85
« Reply #5 on: September 04, 2007, 02:03:01 am »
Thanks SGT, got it to work after mucking around with the driver.
philby
