January 27, 2026, 03:15:31 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Woodworking
Centering the hole for joystick mount
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Centering the hole for joystick mount (Read 3133 times)
childeb1
Trade Count:
0
Newbie
Offline
Last login:August 15, 2020, 04:08:48 pm
I want to build my own arcade controls!
on:
September 03, 2007, 10:08:41 pm »
How do you center the joystick shaft? Do you drill the hole first then route out the recess or vice versa? This is for a bottom mount joystick.
Do you eyeball it or is there a more exact method?
CoreyH
Logged
acevedor2
Trade Count:
0
Full Member
Offline
Last login:May 25, 2024, 08:21:24 pm
Re: Centering the hole for joystick mount
Reply #1 on:
September 03, 2007, 11:28:18 pm »
Easiest way to do it in my opinion is to remove the shaft (usually just a clip holding it on) and then mark the mounting holes. Draw a line from the lower left hole to the upper right hole and then a line from the lower right to the upper left hole. Where they cross at the "x" is the center. Then use a 1 1/8 i believe it is to cut the center hole out. Good luck!
Logged
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
Trade Count:
+1
Full Member
Offline
Last login:
Yesterday
at 04:50:43 pm
Reply #2 on:
September 04, 2007, 10:48:44 am »
I just layout the joystick mounting plate on the CP and drill out the center using a 1-1/8" bit. I haven't come across a joystick that didn't center the stick in the mounting plate.
Logged
Bella's Arcade
DK+
Jack Attack!
Woodgrain Cabaret
Twin Tullys
miles2912
Trade Count:
0
Full Member
Offline
Last login:October 31, 2019, 05:30:24 pm
My first Home Game. Fairchild System F.
Reply #3 on:
September 05, 2007, 12:11:49 pm »
Drill the hole and then center the stick, mark the mounting holes and then drill them. After you confirm the joystick is perfect, route the underside to desired height.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Woodworking
