Author Topic: 100% wood rectangular box  (Read 2901 times)
The cranky hermit
  • Last login:June 03, 2006, 01:35:04 am
  • CP #1: Completed
« on: April 29, 2003, 08:56:26 pm »
Is there anything wrong with making a CP box out of nothing but wood and wood glue, and making it a perfect rectangle? If not, what's a good kind of wood to use? I'm not interested in asthetics. I just want it to be inexpensive and practical.
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
Re:100% wood rectangular box
« Reply #1 on: April 29, 2003, 09:08:32 pm »
The thing about gluing it is, what if a wire comes loose, or a switch on a button breaks, or anything that you need to get inside the box for?  I would at least make one panel of the box be screwed on, so you could take it off and repair anything that breaks.  But that's just my opinion.
unclet
« Reply #2 on: April 29, 2003, 09:48:08 pm »
Seems that most arcade control panel tops are tilted to allow for the resting of the wrists (in a natural position) while gripping the joystick or using the buttons.
Basically, I would think if the control panel top was parallel to the floor (assuming the floor was flat  ;) ) then the player's wrists would be uncomfortable when playing with the joysticks after a period of time.
The cranky hermit
  • CP #1: Completed
« Reply #3 on: April 29, 2003, 09:53:55 pm »
Right. Screws also. So now I have three questions:
Is it OK for the box itself to be 100% wood? No lexan, no plexi, just complete wood?
What's a nice, comfortable angle to mount the top at?
What's a decent, not too expensive type of wood to use?
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
« Reply #4 on: April 29, 2003, 10:42:39 pm »
Well, if looks don't matter, I'd suggest MDF, or ply... melamine would be a nice touch...head out to your local lumber supply store and have yourself a look around.  I've seen some shelving kits that'd look good for cp's by themselves...
Now witness the power of this FULLY OPERATIONAL Mame machine!
unclet
« Reply #5 on: April 29, 2003, 11:08:13 pm »
My control panel box is 100% MDF.  Of course I painted the the box black.  Once I painted it I realized that if I rested by wrists on the top (whichwas now painted black) the black paint would wear off over time (ie: my wrists and hand movements using the joysticks would result in the rubbing of the black paint, thus making it lose it's shine and show wear).  As a result, I plexi-ed the top.
I would go to the local arcade and check out which type of top you feel comfortable with and then simply note the dimensions.  My personal control panel top slopes from a back height of 8-1/4" to a front height 7" and covers 17" deep.... hope that helps.   Note, the slope is gradual.
You can also hold a separate pencil in each hand at the same time and pretend they are joysticks.  If you hold them comfortably (as if they were joystifcks) you will notice the slope of your forearms from your elbow to your wrists.....this is the slope I would recommend using.  After all, it is your forearm and wrists which will be resting on the control panel top most of the time while you play.
Oh yeah, a sheet of 4'x8'x3/4" MDF board is about $15.....pretty cheap if you ask me and gives much better looking results if you do plan on simply leaving the "wood" look.
skirge66
  • Last login:June 03, 2003, 06:25:58 am
  • the stupid will normally punish themselves
« Reply #6 on: April 30, 2003, 02:06:30 am »
just a thought, my skin tends to be very dry, and messing around with bare mdf just sucks the moisture out of my hands, not sure if anyone else has this problem, but it can be painful, not sure how well painting would work, but i wouldn't use mdf unless i had a decent coating of paint, lexan, or laminate on it
skirge66
Diplomacy is the art of saying "nice doggy" until you find a bigger rock to throw
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
« Reply #7 on: April 30, 2003, 05:00:17 am »
I use a difference of 1" for a 10" width box section for the grade on my top surface.
unclet
« Reply #8 on: April 30, 2003, 07:43:55 am »
I guess the MDF did not bother me atall, although you sparked my memory......I seem to remember someone saying they some people might have a reaction to MDF due to the type of glue they use in making it.   I mean when you cut the MDF, the extremely fine dust which is created gets all over and some people have a skin reaction.   :o
I believe this is what I read somewhere....oh well.  I would you a mask, goggles and gloves then...  ;)
PS:  Love these face things -->  :)  ;)  :D  ;D
skirge66
« Reply #9 on: April 30, 2003, 08:07:42 am »
i wouldn't play around with it any other way...besides i'm a super safety freak. like to keep all the body pieces where they belong insides on the insides etc.  ;)
skirge66
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #10 on: April 30, 2003, 09:50:26 am »
My control panel is all wood, glued and nailed.  The top piece is removable.
The top is a combination of 1/2 inch birch ply, 1/4 inch Cherry ply, and solid Cherry 1x2.  The box is 3/4 inch Oak ply.
American Laser Games Wrapper
O2em Rom Utility
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: April 30, 2003, 05:08:47 pm »
If you paint it with a decent paint, yes, you don't need lexan or plexi.  You could go clear if you want, but I suggest at least a couple coats.
(assuming you're sitting at a desk) depends on how tall your torso is, how tall your chair is, how tall the table top is, and how tall the CP is.  Ideally, 15-20 degrees and your froearms and hands are also at 15 degrees.  But if you need to hold you forearms at a higher angle to reach the controls, you might want to go up to 30-40 degrees.
If you aren't picky and will paint it, there's always partical board.  MDF is great, but costs more and needs to be painted.  I don't suggest pine plywood ("soft" wood dents too easily).  Don't know enough about hard woods to help you, but plywood is usually cheaper than plain wood.
Robin
Knowledge is Power
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
« Reply #12 on: April 30, 2003, 05:30:52 pm »
Why are your controls bass-ackwards?
« Last Edit: April 30, 2003, 05:31:08 pm by DeathMonk »
Now with cup beer holders!
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« Reply #13 on: May 01, 2003, 12:43:40 am »
Yeesh, the local home depot just sold me 3 sheets of 4x8x3/4 MDF for $6.80 a sheet...!?!? $15??
Are you using that hard-cored stuff?  The stuff thats like 60 pounds a sheet???
i was going to just cover my panel with Con-Tact paper....well the top part anyhow, but then realized that would probably wear through....so I think I have to go with some type of Lexan top no matter how I slice it...
".....its like a Koala crapped a rainbow in my brain!"
ErikRuud
« Reply #14 on: May 01, 2003, 09:25:03 am »
Because I like them that way! ;D
I've answered this many times already.
The "sort of standard" stick on the left, buttons on the right arrangement did not become common, until long after I stopped going to arcades. My arcade days were from 1978 to about 1982. Games had many different layouts then.  Also the Atari 2600 and Odyssey2 console systems had the button on the left.
So far only one person out of twenty had a problem using my control panel, and I showed him that he could use the player 2 buttons with the player 1 joystick for one player games.
« Last Edit: May 01, 2003, 11:29:12 am by ErikRuud »
O2em Rom Utility
Chris
    • Chris's MAME Cabinet
« Reply #15 on: May 01, 2003, 09:51:42 am »
For the top, you can use particle-board shelving material; these are often pre-laminated in white, black, or woodgrain.
--Chris
--Chris
