Author Topic: what kind of wire to do i use to wire my i-pac??  (Read 1528 times)
robot8319
  • Trade Count: (-2)
  • Last login:August 25, 2009, 11:22:02 pm
« on: August 31, 2007, 10:25:39 pm »
hello i plan rewiring my cabinet for strictly mame.
what kind of wire would i need to do this and where can i buy it from locally like office max lowes or walmart or radioshack..
also whats the difference between 18wg and 22wg gauge wire? is one better the the other?
speaking of the wire what it look like?
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
Re: what kind of wire to do i use to wire my i-pac??
« Reply #1 on: September 01, 2007, 12:24:00 am »
Pretty much any wire will do. Radio Shack calls it "hookup wire". A number of folks around here recommend cat 5 ethernet cable (that's 24awg by the way). Office Max should have that. I couldn't find anything on Lowes.com, but I'd be surprised if they didn't have something you could use.
The difference between 18 and 22 gauge is the diameter. Neither is better, but the more electricity you're going to feed a wire, the larger (lower gauge) you want it to be. The thicker the wire, the harder it is to bend, and the more expensive it is because copper isn't cheap.
What does wire look like? It's long and skinny. Usually it's copper in the middle and has a plastic or other non-conductive jacket on it. It comes rolled up on a spool so that you can fit 100' feet of it in your car without poking anyones eye out. I have provided a picture of wire on a spool and another wire ready for action.
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« Reply #2 on: September 01, 2007, 01:16:07 am »
my whole cabinet is 22, your fine with that just go buy that 50ft roll of thermostat wire and split it youll get 50 foot of white  and 50 ft of red cable, its real cheap forget the exact price.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #3 on: September 01, 2007, 02:26:24 am »
Heck I even used CAT3 with no problems for over 1 year. Of course the controls are all soldered.
My old user name was marlborroman13, but I kicked the habit many years ago!
