Author Topic: Help with Paperboy Med Res Monitor  (Read 4108 times)
BALLS2THEWALL
  • Last login:October 23, 2007, 04:11:09 am
« on: August 30, 2007, 05:48:27 pm »
I have Paperboy with no monitor.   :banghead: I have been searching everywhere for a 19 inch monitor to use.  The only one I can find is Wells-Gardner D9500.
https://www.wellsgardner.com/products/details.asp?iCat=2&iSubCat=10
I have noticed that not many people have experienced this monitor in med res but i did read somewhere when using med res with this monitor that it might cause it to flicker.  I was told by someone that there might be a way to fix that but it would void any warrenty.  I also have been tring to get a hold of tech or customer service at Wells Gardner all day and now i know why people try to avoid dealing with these monitors.  I have invested too much time to just give up.  Please help :notworthy:.  Can u suggest a different monitor?  I havn't seen anyone talk about replacing a paperboy monitor with anything but a refurbished Wells-Gardner 19k7635.  Also does anyone know the exacted frequency for paperboy?  I think it is 24khz
« Last Edit: August 30, 2007, 05:52:57 pm by BALLS2THEWALL »
BALLS2THEWALL
Re: Help with Paperboy Med Res Monitor
« Reply #1 on: September 02, 2007, 06:15:00 pm »
Can anyone help?  There has to be someone who has experience with medium res arcades.
grantspain
« Reply #2 on: September 02, 2007, 06:26:25 pm »
the only one i can suggest is a hantarex polo2 dual sync or a hantarex polostar-but they ain't cheap
otherwise pm rickn at nieman displays to see if he has an alternative to the wg d9500
BALLS2THEWALL
« Reply #3 on: September 04, 2007, 06:37:36 pm »
No help so far.  Seems no one has had any luck replacing a 19 inch medium resolution monitor.  There has to be an anwser somewhere. :timebomb:
ahofle
    • Arcade Ambience Project
« Reply #4 on: September 04, 2007, 06:43:54 pm »
Have you tried looking into the Billabs I mentioned to you in your other thread?
BALLS2THEWALL
« Reply #5 on: September 04, 2007, 06:46:50 pm »
could you give me a direct link to a 19 inch monitor that does 25khz.  i also havnt had any feedback about anyone that has used any 19 inch monitor for medium resolution
ahofle
« Reply #6 on: September 05, 2007, 12:01:57 am »
http://billabs.com/bl19c91t.htm
It's new, so you will probably have to call them to get more information.
BALLS2THEWALL
« Reply #7 on: September 05, 2007, 03:55:28 pm »
Well i called them.  They said they  didnt know if this monitor would work with paperboy.  They said it should work.  And if it doesn't i have to pay for shipping and 15% stocking fee.  Seems like a big risk to take when they cant even tell me if its going to work or not.  I just dont see why if it doesnt work, its got to come out of my pocket.
Wade
  • Last login:December 01, 2025, 08:21:17 am
  • 80's Child
    • Wade's Gameroom
« Reply #8 on: September 09, 2007, 09:28:21 pm »
I have seen scan converters that will do any combo of cga/ega/vga for around $100... you could get one of those and use either a 21" PC monitor (people practically give these away) or a regular cga arcade monitor.
Wade
