Author Topic: PSP - how to hack any PSP with FW less than 3.51  (Read 2575 times)
spystyle
« on: August 28, 2007, 03:13:28 pm »
Hello from Maine,
I just took a "crash course" in PSP hacking.
I had to downgrade my daughter's PSP from 3.11 to 1.50, then apply custom firmware 3.52-4 and figure out how to play ISOs.
I took notes in case I would have to do it again in the future.
I've uploaded my notes and all software i used here:
http://tinyurl.com/6flkoq
It is entirely self contained, you will not need to download anything else. I also simplified the instructions - it is so easy a monkey could do it.
Maybe it could save you hours of Googling and the risk of reading outdated tutorials.
You will need the game "Lumines" to do this method.
I got "Lumines" from GameStop for $34. They are on ePay as well.
Dig it?
Craig
EDIT : I have updated the above (April 2008). Now the pack does this:
1. Any firmware less than 3.51 to 1.50
2. 1.50 to 3.52 M33
3. 3.52 M33 to 3.90 M33-2
I have tested this exact software pack on 3 different PSPs and was 100% successful in hacking them.
« Last Edit: April 25, 2008, 10:16:57 pm by spystyle »
spystyle
Re: PSP - how to hack any PSP with FW less than 3.51
« Reply #1 on: August 28, 2007, 06:32:27 pm »
So the above covers how to:
Downgrade any PSP with firmware lower than 3.50 to 1.50, then up to "custom firmware 3.52-4" by "M33"
Also, how to play ISOs that you've acquired
But for everything else here is a motherlode of tutorials:
http://forums.afterdawn.com/thread_view.cfm/454995
« Last Edit: August 30, 2007, 10:56:00 am by spystyle »
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« Reply #2 on: September 11, 2007, 03:07:27 pm »
Spystyle,
Great write up.  Just went throught the process from start to finish last night.  Worked like a charm.  Had a couple issues with corrupt data.  I found that if I remove my flash card before I disconnect from the PC everytime this does not happen.  Meaning that I pull out flash card, hit "O" on PSP to disconnect USB from PC, then reinsert my flash card and navigate through PSP.  It is kind of a pain, but works.
This little process has given my PSP new life! :notworthy: :notworthy:
Many Thanks!!! :applaud:
spystyle
« Reply #3 on: September 11, 2007, 03:30:14 pm »
You are welcome :)
