Author Topic: Mala, can you combine emulator lists?  (Read 5922 times)
TroyO
  • Last login:April 05, 2021, 02:52:54 pm
« on: August 28, 2007, 02:57:02 pm »
I have been thinking about how to set up a tree so that games are not segregated by emulator type. Can that be done? I'm thinking someone chooses...
Games
---------Action
-----------------Joystick
--------------------------- List of all games from all emulators that match
So, for instance you'd have:
Frogger (Sega Set 1) MAME
Frogger (Sega Set 2) MAME
Frogger (Atari 2600) MESS
Frogger 2 (Aari 2600) MESS
Frogger (Atari 5200) MESS
Frogger 2 (Atari 5200) MESS
I haven't messed with Mess much, so maybe there's a way to get a list from that but how do you (Can you?) mix and match multiple platforms in one gamelist? (Preferably without having to hand edit?)
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
Re: Mala, can you combine emulator lists?
« Reply #1 on: August 28, 2007, 02:59:02 pm »
No, but I could be wrong..
TroyO
« Reply #2 on: August 28, 2007, 03:19:05 pm »
Ahh well, figured it was worth a shot. A friend of mine pointed out that most folks wouldn't think in terms of "The Frogger that I liked was on the Atari 5200, I think..." but just want to play "Frogger" and don't know/remember/care what it was run on so it might be easier for them to navigate to it that way.
gonzo90017
loadman
  • Moderator
    • MaLa
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #5 on: August 28, 2007, 08:05:44 pm »
Here are a couple of tutorials of how to do it.
http://forum.arcadecontrols.com/index.php?topic=68854.0
http://forum.arcadecontrols.com/index.php?topic=68419.0
SGT and UncleT are so clever   :notworthy:
If I was clever, I would write my own plugins instead of using yours.    :applaud:
(Of course why should I when yours works so great)
« Last Edit: August 28, 2007, 08:15:11 pm by SGT »
loadman
  • Moderator
    • MaLa
« Reply #6 on: August 28, 2007, 08:12:48 pm »
Edit... (Of course why should I when yours works so great)
We should get a room   :laugh2:
Can you use Delphi or C++?  I only started with Delphi a year ago...
http://wiki.arcadecontrols.com/wiki/Mala_Plugins Have a look at the 'Creating section'.
I know you have more than enough smarts to try (I would help if you want) and it's FREE!!
SGT
« Reply #7 on: August 28, 2007, 08:25:34 pm »
I currently use VB.  I have done a little bit in C, but I'd like to try Delphi.  I have been kicking around whether it would be possible to create a plugin to execute different emulators within a gamelist.  This would be better than moving roms and creating batch files.  I guess my biggest question is:
In the game selected event, does Mala allow your plugin to cancel the event, or is Mala definitely going to execute mame.exe after the plugin code is executed?
« Last Edit: August 28, 2007, 08:28:08 pm by SGT »
loadman
  • Moderator
    • MaLa
« Reply #8 on: August 28, 2007, 08:58:16 pm »
Sorry for the thread Hi-jack Guys  :-[
'MaLaGameSelected' event just means the is the higlighted game in the list. When it does it sends the Plug-in the following info:
                 'EVENT: Game selected' + nl +
                 'Name: ' + String(g.Description) + nl +
                 'Manufacturer: ' + String(g.Manufacturer) + nl +
                 'Genre: ' + String(g.Genre) + nl +
                 'Year: ' + IntToStr(g.Year) + nl +
                 'Clone of: ' + String(g.CloneOf) + nl +
                 '-------------------- INPUTS ---------------------------------' + nl +
                 'Coins: ' + IntToStr(g.InputCoins) + nl +
                 'Buttons: ' + IntToStr(g.InputButtons) + nl +
                 'Players: ' + String(g.InputPlayers) + nl +
                 'Control: ' + String(g.InputControl) + nl +
                 '-------------------- VIDEO ----------------------------------' + nl +
                 'Screen: ' + String(g.VideoScreen) + nl +
                 'Orientation: ' + String(g.VideoOrientation) + nl +
                 'Video size: ' + IntToStr(g.VideoWidth) + 'x' + IntToStr(g.VideoHeight) + nl +
                 '-------------------- DRIVER ---------------------------------' + nl +
                 'Status: ' + String(g.DriverStatus) + nl +
                 '-------------------- CONTROLS.INI ---------------------------' + nl +
                 'Control: ' + String(g.Controls) + nl +
                 'JoyUp: ' + String(g.JoyUp) + nl +
                 'JoyDown: ' + String(g.JoyDown) + nl +
                 'JoyLeft: ' + String(g.JoyLeft) + nl +
                 'JoyRight: ' + String(g.JoyRight) + nl +
                 'Button1: ' + String(g.Button1) + nl +
                 'Button2: ' + String(g.Button2) + nl +
                 'Button3: ' + String(g.Button3) + nl +
                 'Button4: ' + String(g.Button4) + nl +
                 'Button5: ' + String(g.Button5) + nl +
                 'Button6: ' + String(g.Button6) + nl +
                 'Button7: ' + String(g.Button7) + nl +
                 'Button8: ' + String(g.Button8) + nl +
                 '-------------------- ROMFILE --------------------------------' + nl +
                 'Rom name: ' + String(g.Rom) + nl +
                 'Rom path: ' + String(g.RomPath) + nl +
                 'Rom extension: ' + String(g.Extension) + nl +
                 '-------------------- STATS ----------------------------------' + nl +
                 'Game played: ' + IntToStr(g.Played) + nl
But I assume you mean 'MaLaGameStart'.  And yes after the Plug-in is executed it wil continue to launch Mame or whatever emulator is set in MaLa.
But PM Swindus. He is full of simple solutions  :-)
SGT
« Reply #9 on: August 28, 2007, 09:36:45 pm »
Last post on this topic, sorry guys.  Yep, I should have said MalaGameStart event.  I was hoping for a way to cancel the event similar to VB's CancelEvent method.  With that you could possibly substitute your own code for what Mala is doing, namely executing the emulator and commandline.  I can see why Swindus would think this would be a less than ideal situation.  I guess I could create a batch file on the fly based upon the the configuration of the other_emus and configure Mame to run it...  Anyway, thanks for the link to the wiki entries.  I may have some more questions for you, but I'll put those in another thread. :cheers:
TroyO
« Reply #10 on: August 29, 2007, 02:54:06 pm »
Haha, no problems on hijacking, I've always wanted to learn greek anyway. ;-)
Besides, you guys may crack the coding thing to make it easy to do which means I won't have to go hacking around to figure it out. :-)
Thanks for the links, and the plugin effort.
Katana Man
  • Last login:September 22, 2024, 12:10:44 pm
« Reply #11 on: August 29, 2007, 03:32:26 pm »
Games
---------Action
I think this is currently Mala's biggest missing feature.  I was really quite surprised to see such a sweet front end with the ability to set up categories/subcategories, but no way to make a list from them. I hope it gets added in the near future.  I'd love to see the MaleGamelist.exe program have this ability, plus inside Mala:
Right click
  Add to Game list:
    -> 4 player Simultaneous list
    -> Dual spinner list
    -> etc....
This way, I could go to my Mame games, right click and add Gauntlet to the "4 player Simultaneous list".  Then I could swing over to NES and add SuperSpike Volleyball to the "4 player Simultaneous list."
« Last Edit: August 29, 2007, 03:37:01 pm by Katana Man »
