Author Topic: can the laminated cpo adhesive from mamemarquees be applied to curved surface?  (Read 1717 times)
ARTIFACT
the title says it all
i want my cp artwork to bleed/wrap around the front and under my cp. the curves are about 0.5'' radius (2 curved edges) and then 3 flat surfaces: top, front, bottom
i love the description on the MM site (durable, etc) and although the top surface does have plexi / lexan, i tink adhesive backed sounds like what i want (especially if i wrap it like that.
is their laminated stuff rigid?  or should it work?
Thanks for your input!
  • Last login:Yesterday at 05:27:25 pm
I was able to roll it around my galaga CPO
ARTIFACT
perfect
is the adhesive easy to apply?
(the way it peels...)
shardian
perfect
Here is the Wiki page on applying CPO's.
http://wiki.arcadecontrols.com/wiki/Applying_CPOs
ARTIFACT
thanks - I should have looked
ARTIFACT
the wiki doesn't answer my specific question which was about the mamemarquees adhesive backing ... Are there things I need to watch for when peeling it, should I peel small amounts while applying it, or not, etc.
I can use common sense of course, but I prefer to be paranoid and be prepared!
Unless your a klingon, or your fingers are covered with super glue - the backing comes off very easily. Like wax paper.
shardian
Yeah, I totally didn't get what you were asking. The backing comes right off. That would kind of defeat the purpose if it was stuck to the adhesive. ;)
ARTIFACT
OK :)
I just wanted to see if there was any tips on applying it after peeling the backing... to avoid air bubbles, or anything else I am not realizing may happen
What I do is pray a lot. So far it's been working really well. I'm only half kidding...
I lift up one edge and apply it to a line I've drawn that I know is straight. Then I slowly lift the backing and apply it as I lift the backing - smoothing it out for air bubbles or anything.
ARTIFACT
this answered all of my questions:
http://www.mamemarquees.com/pub/
(article)
shardian
(article)
Hehe, I went to get you that link yesterday, but then got distracted by the bargain bin. ;D Glad you found it though.
