Author Topic: Rolling Monitor... could use advice  (Read 1824 times)
baccabean
  • Newbie
  • Last login:August 26, 2007, 11:48:12 pm
« on: August 26, 2007, 11:36:09 pm »
I am learning to walk when it comes to the realm of arcade machines. I have a  street fighter Dynamo Cab, and changed the board over to a MKombat jamma pcb and the screen is rolling. I will be more than willing to provide information on any piece if you point me in a direction. The SF2 board is fine the roll occurs with the new board.
I am sorry for not posting all the info needed to get a solid reply, but I am new and learning.
Is the board shot or is there hope?
grantspain
Re: Rolling Monitor... could use advice
« Reply #1 on: August 27, 2007, 02:56:34 am »
when you swap out boards sometimes you need to adjust the monitor,in your case the hold/shift adjustments just need a tweek
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 27, 2007, 11:07:33 am »
Yes, all Jamma video is not exactly the same from board-to-board. It is very common to need to adjust some controls on the monitor when swapping boards.
