Author Topic: Horizontal Lines at top 1 inch of WG K7500 Monitor  (Read 4502 times)
albrigsr
  • Last login:July 29, 2016, 09:24:49 am
« on: August 26, 2007, 10:58:46 pm »
I have a Golden Tee Complete that has the above problem (Pictures included).  I included pictures of the problem as well as of the monitor as I don't know if it is the original monitor.  The lines show up consistently regardless of color (except when the screen is black).  I do also notice faint bottom to top rolling waves but not consistently.  I did have an earlier problem with the monitor in which the picture was horribly wavy and unplayable but a person came and took the boards and fixed it (installed new capacitors, etc).  No problems after that until now which has been roughly 6-8 months.  I appreciate any help and guidance that you can provide!
Thank you,
« Last Edit: August 31, 2007, 12:33:48 pm by albrigsr »
albrigsr
Re: Horizontal Lines at top 1 inch of GT Complete Monitor (Unknown Model)
« Reply #1 on: August 26, 2007, 10:59:57 pm »
More Pictures
albrigsr
« Reply #2 on: August 26, 2007, 11:04:17 pm »
Even More Pictures
albrigsr
« Reply #3 on: August 26, 2007, 11:05:56 pm »
Final Picture - Thanks!
SirPeale
  • Green Mountain Man
« Reply #4 on: August 27, 2007, 07:50:56 am »
You have a K7500.
albrigsr
Re: Horizontal Lines at top 1 inch of WG K7500 Monitor
« Reply #5 on: August 31, 2007, 12:34:20 pm »
I hate to bump the thread myself but really would appreciate some help.  Thanks!
SirPeale
« Reply #6 on: August 31, 2007, 01:05:11 pm »
Looks to be a minor sync issue.  If this were a K7000 I'd tell you to adjust your 50/60Hz pot.
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
« Reply #7 on: September 02, 2007, 11:18:49 am »
You said that it had this problem before and some capacitors cleared it up. It looks to me like it needs this service again. Does the cabinet get pretty hot? I've noticed that when my Nintendo Sanyo monitors do this it is due to a couple medium size capacitors near the flyback that start leaking.
Kevin Mullins
    • Me on Myspace
« Reply #8 on: September 02, 2007, 04:06:15 pm »
Looks like a minor vertical foldover issue to me.
Can you adjust the vertical height? (make the picture smaller/shorter)
albrigsr
« Reply #9 on: September 03, 2007, 03:07:57 am »
ncflagg,
It had a problem before but not one similar to this.  I just wanted to mention the monitor's history.
Kevin,
I will try to adjust the vertical height and see what happens.
Both,
I do appreciate the help!
Mrjamma
  • Last login:April 01, 2009, 04:28:41 pm
« Reply #10 on: April 01, 2009, 04:06:41 pm »
Replace C 610  2.2uf  @50v
and       C 613  100uf @50v
Both are located right in front of the U601 vertical IC at the right edge of the board.
I just fixed this exact problem on a K7500 today, it looked just like your top pic with retrace lines at the top of the screen only.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #11 on: April 01, 2009, 09:32:44 pm »
a faulty output ic can also cause this.
have also seen problems with the boost diode connected to that 100uF cap. ;)
qrz
