Author Topic: Model2 =+ Daytona USA = "Network card not connected, cancelling"  (Read 3288 times)
ARTIFACT
I'm sure this is a silly newbie thing again  .......... ;D
is there a config / switch I need to set on Model2 emu (Nebula team's) to launch and play Daytona?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Model2 =+ Daytona USA = "Network card not connected, cancelling"
« Reply #1 on: August 22, 2007, 07:23:37 am »
Press F2 and go to game system. Change link id to single.
ARTIFACT
« Reply #2 on: August 22, 2007, 02:18:02 pm »
thank you very much!
mxd
  • Last login:January 24, 2012, 05:44:38 am
« Reply #3 on: September 26, 2011, 11:18:06 pm »
sorry to revive such an old thread.
Is there a way to have the rom configured so I only need to change from master to single once ?
Or is there another option so it still thinks it's a master but no other player playing ?
I just put the m2network.ini in the directory last night but it still is waiting for a connection.
thanks
Matt
mxd
« Reply #4 on: September 27, 2011, 07:00:54 am »
figured it out, when I press unload rom on v1.0 my emu crashes so the config is not updated. When I then do the setup within v0.9 and unload my config stays set.
thanks
« Reply #5 on: September 27, 2011, 08:00:10 am »
I hit F2 and I cant even figure out how to set it to single.  Can you post your cfg?  Should I use .9 for Daytona instead of 1.0?
mxd
« Reply #6 on: September 27, 2011, 05:08:01 pm »
you hit f2, then you use your VR buttons (what ever you had them configured as) to traverse the menu, then you select (start key I think) game system then you can change to single etc..
The important thing to remember is to uload the ROM so the config is saved.
