Author Topic: Mounting a 19" monitor in a 25" Dynamo Cab  (Read 1696 times)
rotheblog
  • Last login:March 28, 2019, 10:27:39 pm
    • Rotheblog Arcade
« on: August 20, 2007, 11:09:10 am »
Has anyone here done this?  I did a search, but most of the results I got where talking about what size monitor could fit, not how it was mounted.  I have a Dynamo cab that can fit a 25" monitor, but I only have a 19".
Are there some brackets that people have used to do this?  I am not much into carpentry, and worry about the weight of any monitor in a custom situation that I might build, that is why I was hoping for some sort of metal monitor brackets that might work.
Thanks for the help.
Rotheblog.com - Classic arcade games blog
CoinOpSpace.com - A social network for collecting arcade games, a friendly community, and a focus on easy content sharing.
I partner with This Old Game to vectorize your arcade artwork.
No PM's. Email at rothecreations@gmail.c
shardian
Re: Mounting a 19" monitor in a 25" Dynamo Cab
« Reply #1 on: August 20, 2007, 11:34:05 am »
I'd recommend you cut a piece of plywood to fit the cabinet on the monitor mounts (the 2x4's inside the cabinet to mount the monitor mounts to), then cut out a hole for the monitor. My dynamo cabinet was done this way, as were alot of cabinets. Here is a link to Knevil's twin Taito project that kind of outlines the monitor mount I am speaking of.
http://forum.arcadecontrols.com/index.php?topic=65678.msg665571#msg665571
rotheblog
    • Rotheblog Arcade
« Reply #2 on: August 20, 2007, 12:25:22 pm »
Thanks for the reply, this would be kind of like an Atari Dig Dug.  I hadn't thought of that yet, that is a good idea.
I still don't have the tools to do this even, I don't have much of any carpentry tools.
So if anyone else reads this, there is one solution, but is there a solution where I can just buy some parts to throw in to the cab and have it solve the problem?
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #3 on: August 20, 2007, 12:53:52 pm »
On mine, I builted a shelf to seat the monitor on their, but that's assuming that your is not an arcade monitor.
Green Giant
« Reply #4 on: August 20, 2007, 01:04:10 pm »
Chances are that no one will sale parts ready made for your problem.  If you really need this done for you, you will have to hire someone to do the work.
Toxic Arcade, my first build
rotheblog
    • Rotheblog Arcade
« Reply #5 on: August 21, 2007, 07:34:33 am »
Thanks for the other two replies, I am going to go the wood route, I think I may have found someone who has some scrap.  I just have to check the thickness and I am good to go.
shardian
« Reply #6 on: August 21, 2007, 01:02:57 pm »
If that falls thru, you can buy 1/4 or 1/2 sheets at Home Depot. I bought a 2'x2' sheet of plywood for my monitor mount for a few bucks at HD a while back.
