Author Topic: Ready to put Trackball into my cab, concerns/ questions  (Read 1390 times)
mrserv0n
  • Last login:May 25, 2021, 09:20:06 pm
« on: August 19, 2007, 12:17:59 am »
Here is my cab
Here is a pic of the same cab modded  with the trackball where I want it.
It looks like he removed his coin slots to get the plate to mount, I do not want to do this, I want my coin slots.
What are my options here? I can give measurements if needed.
There are many trackballs with this layout
Would this trackball without the top plate work with my cab? I have never installed one before, The die hard cabinet is made of thick plastic btw, dont know if that matters or limits my options.
Lastly, What track ball / hook ups do I need to hook this into my cab, I seen the mouse hacks and such and thats creative and all but just want to buy the easiest setup possible, I do this for the games not the invention side.
« Last Edit: August 19, 2007, 12:24:42 am by mrserv0n »
mrserv0n
Re: Ready to put Trackball into my cab, concerns/ questions
« Reply #1 on: August 19, 2007, 12:33:12 am »
This Might be my ticket right here... Looks like it would just mount like my joysticks do  from the top is this correct? And from the sounds of it I can just plug this straight in USB and MAME away..?
Red
  • Last login:November 07, 2017, 08:37:51 am
« Reply #2 on: August 19, 2007, 02:00:24 am »
Where'd you get that mrserv0n?  Do you have a model #?
mrserv0n
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #4 on: August 19, 2007, 01:08:20 pm »
As long as there's room under the control panel for the coin slots and the trackball mech, you're fine.  Keep in mind that that trackball's mounting screws go in a diamond (N E S W) rather than a square (NW NE SE SW).   I think anyway...
BobA
  • What Me Worry?
« Reply #5 on: August 19, 2007, 04:01:33 pm »
Look at Buy/Sell  where you will find the same item for alot less then Happs charges.
It will still be a tight fit what about a smaller trackball?
mrserv0n
« Reply #6 on: August 19, 2007, 07:07:02 pm »
Well Boba, I know 3" is the standard and I have played with those, I have never used/seen a 2 1/4 in person so I don't know if it would be just as good or not.. Judging by the dimensions it knocks off about .75-.85 of an inch in both Length and width, I have to grab the measure tab and see what I am working with..
Ok I have I basically have 5.5" Length and 7" width..
Judging by the diagram without modding into my coin slots I am about .3 in. short of the 3" ball.. The 2 1/4 is only 4.5inch radius so that should fit nice and smooth.. Hopefully the size of the ball doesn't disappointin performance ..
« Last Edit: August 19, 2007, 07:20:42 pm by mrserv0n »
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #7 on: August 20, 2007, 02:33:56 pm »
Looking at your cabinet, have you consider getting a coin door instead.  The metal blank door that you have at the bottom can be taken out and a coin door can take it's place.  This would free up quite a bit of room.  The replacement coin door would just be your over under Happ coin door.
