Author Topic: monitor is very dark. help plz.  (Read 5400 times)
F_Zero45
  • Last login:July 15, 2013, 10:10:32 pm
« on: August 16, 2007, 01:56:44 am »
I have a wells gardner 25k7193 and my picture is way dark. Adjusting the contrast makes the colors neon like and the blk level makes the entire screen either pale/faded or very dark. I cannot get a crisp picture. I tried different game pcbs and it's dark so I know it's not the game board but something with the monitor. I also tried adjusting the 'screen' dial on the flyback, i believe is what it's called, and it doesn't fix the problem but pretty much does what adjusting the blk level does.
F_Zero45
Re: monitor is very dark. help plz.
« Reply #1 on: August 16, 2007, 02:02:18 am »
Also to play at night I have to turn the overhead light off to see the screen b/c it's so dark.
sorry for the double post. my edit isn't working
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 16, 2007, 02:34:20 am »
And you've done a fresh capkit on it?
F_Zero45
« Reply #3 on: August 16, 2007, 03:11:34 am »
not a fresh one. :P
The last time it was capped was less than a year ago and then went into storage. I just bearly started using it about a month ago.
grantspain
« Reply #4 on: August 16, 2007, 05:36:17 am »
it is always worth checking the power supply +5 is adjusted correctly as this can cause the same problem.
if still no joy then try adjusting the neck board colour gains and background,don't forbet the contrast pot as well
i usually set my monitors by turning all the colours backgrounds and gains,brightness and contrast to minimum then turn the screen volts so you can just make out a pic,then add a bit of brightness,then add contrast a little,now add a small amount  of each colour background then the colour gains.use a colour bar from a test menu to help
F_Zero45
« Reply #5 on: August 17, 2007, 03:56:47 pm »
checked voltage and replaced ISO transformers but still the same thing. :hissy:
grantspain
« Reply #6 on: August 17, 2007, 05:42:43 pm »
have you done the other things i suggested yet?
Ken Layton
  • Guru
  • Technician
« Reply #7 on: August 17, 2007, 05:54:16 pm »
There are 3 non polarized electrolytic capacitors near the video input connector. These do go bad, but they are not included in the capkits. These caps go open circuit and cause a sharp drop in picture brightness.
Also, remember that capacitors (even new ones or fairly new ones) can fail at any time for any reason.
Kevin Mullins
    • Me on Myspace
« Reply #8 on: August 17, 2007, 07:18:32 pm »
Ditto ....
Turn everything down and adjust the SCREEN voltage pot on the flyback until a pic starts to show. Then re-adjust the rest of the brightness, contrast and color pots to suit you.
If this isn't enough then go with the caps Ken mentioned.
F_Zero45
« Reply #9 on: August 18, 2007, 05:43:08 am »
so what you're saying is to turn down contrast, brightness and ALL red, green blue pots down all the way and then using the screen pot on the flyback turn it until i get a picture then add the colors and contract?
F_Zero45
« Reply #10 on: August 18, 2007, 09:29:48 pm »
OK. I tred it and it didnt seem to fix the problem. :dunno
it's probablly what ken said.
Ken Layton
  • Guru
  • Technician
« Reply #11 on: August 19, 2007, 12:36:20 am »
If yours has a ZENITH picture tube it's possible it may be going bad and might need to be rejuvenated.
F_Zero45
« Reply #12 on: August 21, 2007, 02:27:23 am »
Ken, can you give me more info on the 3 non polarized electrolytic capacitors? ie. where are they(pic of possible) where can I get replacements
thanks
Ken Layton
  • Guru
  • Technician
« Reply #13 on: August 21, 2007, 10:41:46 am »
C4, C5, C6. Located near integrated circuit IC1. All three of these caps are the same value: 10 uf @ 25 volts non-polar. Bob Roberts should have them.
F_Zero45
« Reply #14 on: August 22, 2007, 02:46:33 am »
Thanks. that did help but now. it's like there is no white color. I go to like a color bar test and the block that should be white is a dark grey :dunno
F_Zero45
« Reply #15 on: August 24, 2007, 05:27:50 am »
Anyone?
ken? :timebomb:
grantspain
« Reply #16 on: August 24, 2007, 05:32:54 am »
whats the video source??
F_Zero45
« Reply #17 on: August 24, 2007, 05:36:44 am »
First I tried a pc using arcade VGA then I put in my Mortal Kombat board and both show same thing. The picture is there and colors are good but in the diag test  , or anything for that matter, white shows up as a grey color.
grantspain
« Reply #18 on: August 24, 2007, 05:42:56 am »
and it stays grey when you turn up the brightness/contrast or screen volts?
the red/green and blue are rich without ghosting
F_Zero45
« Reply #19 on: August 24, 2007, 05:59:43 am »
It only turns white when I turn the contrast up all the way but that ruins the clearity of the picture
grantspain
« Reply #20 on: August 24, 2007, 08:23:10 am »
well its either the tube dying or your setting the colours/contrast/brightness/screen volts/focus badly
i had a sanwa monitor do a similar thing whereas all the colours were present but you could not get richness and clarity,no matter what adjustments i made i could not get it perfect-in the end i swapped the tube and hey presto a perfect picture and this monitor was only 3 years old on a sega outrun 2
maybe you gonna have to adjust to the best pic and live with it
Ken Layton
  • Guru
  • Technician
« Reply #21 on: August 24, 2007, 10:36:54 am »
Put the tube on a rejuvenator to analyze the internal condition of the tube. As I asked before (but did not get an answer) is this a Zenith brand tube?
F_Zero45
« Reply #22 on: August 24, 2007, 06:16:03 pm »
Sorry, it is a Zenith. Whom woul I go to that would have a rejuvenator?
F_Zero45
« Reply #23 on: August 24, 2007, 09:24:31 pm »
here's a pic. the middle bar is supposed to be black and the top and bottom bars are supposed to be white. The blk level is down all the way btw.
Ken Layton
  • Guru
  • Technician
« Reply #24 on: August 25, 2007, 11:37:59 am »
Looks like the focus adjustment is way off. I think you've got a weak tube.
Many tv repair shops have a rejuvenator. Cost is between $35 to $75 to have them test your tube and rejuvenate if needed. You'd need to bring them the entire monitor.
Some forum members here own rejuvenators and one may be located near you. Suggest posting a thread asking for assistance near you.
