Author Topic: Mala: Way to disable “right-click” menus??  (Read 2652 times)
Fat-Johnny
  • Last login:April 14, 2023, 09:23:33 am
« on: August 13, 2007, 10:08:21 am »
Is there any way to disable the “right click” function in Mala??  Basically, I have two buttons on my control panel that are the mouse left/right click buttons.  I don’t want anybody using the cab (friends, parties, etc..) to be able to right-click, and bring up that menu to go into the options and stuff, and start messing with things.  I want my front end as locked-down as possible!!
So my questions/thoughts are:
1) Is there any way to disable the right-click?  If there is not, maybe a suggestion would be a setting in the .ini file (something like  mouse_right_click=0) to enable/disable it.  That way, I can go in there in Notepad, and enable it for when I am setting things up and tweaking, but then before I have a party, I can go in and lock it down.  No need to have an option in the GUI, but make it editable within Notepad.
2) Maybe a way to re-map the right-click to some other keystroke that I am not using on my CP?
Please let me know if this is possible.
Thanks,
fat-johnny
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Mala: Way to disable “right-click” menus??
« Reply #1 on: August 13, 2007, 11:51:09 am »
Try this:
loadman
  • Moderator
    • MaLa
« Reply #2 on: August 13, 2007, 06:40:11 pm »
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #3 on: August 13, 2007, 07:16:48 pm »
Is there any way to disable the “right click” function in Mala??  Basically, I have two buttons on my control panel that are the mouse left/right click buttons.  I don’t want anybody using the cab (friends, parties, etc..) to be able to right-click, and bring up that menu ...
...Is there any way to disable the right-click?  If there is not, maybe a suggestion would be a setting in the .ini file ...
 ...Maybe a way to re-map the right-click to some other keystroke that I am not using on my CP?...
... Deja-vu ...  ;D
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
