Author Topic: Windows Shell Help  (Read 1144 times)
CartmanDP1
  • Last login:October 08, 2008, 05:22:34 pm
Windows Shell Help
« on: August 12, 2007, 08:44:59 am »
I followed the instructions in the wiki on how to run my frontend in a shell and it worked great. The only issue is that i need to get back to the desktop, so i opened the task manager and went to file>run and typed in "explorer", all that this did was open My Documents rather than starting windows
RitchieTheBrit
  • Last login:September 29, 2015, 12:03:36 pm
    • The Urban Dead Survivor Diaries
Re: Windows Shell Help
« Reply #1 on: August 12, 2007, 08:53:17 am »
Hmmm, that is a bit weird.  This is how I always used to return to a windows shell enviroment.
I would hazard a guess that explorer is already running.  If it is, calling another instance will simply open an explorer window in your documents folder.  I suggest checking this by booting into your FE, open task manager, and then checking for explorer under the process tab.  If it is there, than it is already running.
Well I say let's get out there and TW*T it!
One good knee in the happy-sacks and it'll go down like any other smegger!
CartmanDP1
« Reply #2 on: August 12, 2007, 09:03:15 am »
I was able to fix my own problem, i lied when i said i followed the wiki, i actually missed the very first step somehow where you change SYS to USR, everything else worked without the change.
