Author Topic: Plug-In - 'Rotate' MaLa - V1.0 Beta A  (Read 5455 times)
loadman
  • Moderator
  • Last login:Yesterday at 07:18:10 pm
    • MaLa
« on: August 11, 2007, 06:33:59 am »
This could be of use to some Mame cocktail table owners.  like 'squirrellydw'  ;)
You can get MaLa to rotate after a game based on a rom list.
See included read-me for details  ;D
« Last Edit: August 12, 2007, 02:10:31 am by loadman »
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Plug-In - 'Rotate' MaLa - V1.0 Beta A
« Reply #1 on: August 11, 2007, 10:54:33 am »
This feature was not already standard in mala?  I thought you could rotate mala acording to the game?
loadman
  • Moderator
    • MaLa
« Reply #2 on: August 11, 2007, 06:22:10 pm »
You can, this is to overide mame.xml. EG rotate it back just for some games.
This is just of use to a 'few' cocktail owners who for example:
I have a 3 sided cocktail table and most games work great but I only have a trackball and spinner on the 3rd CP.  Some games like Centipede I have set to play vertically on the horizontal screen side.  When I exit the game it rotates the MaLa game list menu like it is set up to do ..................................BUT I don't want it to rotate after that game.  Anyway can I change this so it doesn't rotate?
Maybe squirrellydw will be the only one who uses it. I dunno.  :dunno I just made the plug-in as it was the first time I had made an object from scratch using Delphi (as the plug-in runs in the background and waits a sec before it takes action) and it also uses the new 'MaLa messages' API to control MaLa externaly.
So in a nutshell it was a request that was not worth putting into MaLa itself. Hence I made the Plug-in
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #3 on: August 11, 2007, 06:27:50 pm »
thanks, I will test this out soon
I b**ch. People listen!!
loadman
  • Moderator
    • MaLa
« Reply #4 on: August 25, 2007, 11:46:50 pm »
Not trying to rush you but any idea when you might test this for me please  ;D
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: August 26, 2007, 02:51:25 am »
Again loadman comes through with the goods! Great work my man  :applaud:
squirrellydw
« Reply #6 on: August 26, 2007, 01:23:49 pm »
sorry, yes it works.  I have added a couple games to it and no problems so far.  Nice job and thank you
loadman
  • Moderator
    • MaLa
« Reply #7 on: August 26, 2007, 07:30:11 pm »
:cheers: :cheers:
philby85
  • Last login:August 28, 2008, 08:25:17 pm
« Reply #8 on: August 26, 2007, 07:58:18 pm »
Great work as always Loadman!
You should be the first Mala Legend! annoited by Sir Swindus himself!
Good on ya mate.
philby
