Author Topic: Where do I find R,G,B,CompVid,ground on older TV with RF socket.  (Read 1356 times)
deuce2002
  • Last login:December 30, 2003, 08:37:51 pm
  • HELP !!!
I Have an older TV with only a RF arial socket at the rear & I would like to find out where the Red, Green, blue & comp Video cables are as I want to wire my Sega Saturn up permantly to my TV so it cant be used for anything else. ???
MameFan
Re:Where do I find R,G,B,CompVid,ground on older TV with RF socket.
« Reply #1 on: April 27, 2003, 12:05:53 pm »
You can't.
And don't even think about cracking open the case and finding the spots on the board.  TV's work with a "hot chassis" -- the ground of the internal TV frame is actually 120 volts HOT if you touch it you will get a massive shock.  Therefore connecting anything to any points on the board from a grounded device such as a home video game console will first send 120 volts back into the home game, destroying it, and then burn up the tv by grounding it.
That's why the connectors on the back of the set are always protected by capacitors inside that allow the frequency through but not the voltage.
Unless your TV is european and has a SCART connector that allows RGB inputs, it can't be (easily) done.    YOu can possibly buy one of those replacement arcade chassis for it and mount it inside and get pure RGB, but then you'd have to amplify your video signal from the .7 volts from the video game system to 1.5 to 4 volts needed by the arcade chassis.
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« Reply #2 on: April 27, 2003, 05:41:54 pm »
was there an standard RF lead for the Saturn? i'd check eBay for one...if not, just get an RF modulator from an electronics store (probably about $20) with composite in - this'll convert the signal to RF...
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
