Author Topic: Quick 49-way stick question  (Read 748 times)
« on: August 07, 2007, 09:17:22 am »
Does the connector have a pin 'missing' part way along?  I am pretty sure this is right, just wanting to check I haven't somehow broken off a pin...it's been a long while since I looked at it...
I'm talking about the Happ type btw.
Cheers
NoOne=NBA=
Re: Quick 49-way stick question
« Reply #1 on: August 07, 2007, 09:24:00 am »
Yes.
Thats the key, so that you can't connect them backward--at least when you connect it to a proper harness.
You can connect them backward if you are using a floppy connector, so be careful.
