Author Topic: running batch files through front end, sound ?  (Read 1143 times)
rlehm
  • Last login:September 30, 2010, 09:04:25 pm
« on: August 03, 2007, 04:27:09 pm »
When launching "Geometry Wars" through my front end (batch file) there is no sound. when running it without the front end, it has sound. what gives?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: running batch files through front end, sound ?
« Reply #1 on: August 03, 2007, 04:50:00 pm »
What does the batch file look like?  In the batch file, you need to CD to the directory that you are running the program from before executing the program so the program can find all of its needed components.  This MAY be the problem.
Austin.Wolff
  • Last login:February 04, 2011, 03:53:32 pm
« Reply #2 on: August 03, 2007, 05:39:24 pm »
My guess is wrong parameters.
rlehm
« Reply #3 on: August 04, 2007, 02:43:20 am »
in maximus arcade, you simply point to the exe, and it makes the .bat(batch) file for you. There is an area that you can add commands for it while opening files, i think that's where i need to add something....
Havok
  • Trade Count: (+17)
  • Last login:July 11, 2025, 01:29:48 am
« Reply #4 on: August 04, 2007, 02:33:11 pm »
Right click on the icon you launch it with, and select properties. it should have the parameters there. Then you can plug those into your front end...
