Author Topic: need help with ipac4  (Read 1296 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: August 03, 2007, 03:16:58 am »
now i have ipac4 set up
but i run into this odd problem
the joystick will not "stay pressed" you know?
like if i wanted to make a guy run left i move joystick left but he only takes one step and stop because it will not stay pressed like you would do on your keyboard.
how do i fix this?
My website: www.bossyman15.com Lots of arcade pictures inside!
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
Re: need help with ipac4
« Reply #1 on: August 03, 2007, 10:41:32 am »
Is your joystick switch for "left" staying closed?
You need to a continuity meter or some way of
seeing if the ipac is seeing the switch closed
all the time or just a brief moment.
Also, after you hooked up your IPAC, does your
keyboard still work as described?
bossyman15
« Reply #2 on: August 03, 2007, 03:22:08 pm »
nevermind i fixed it. ipac4 was plugged into wrong PS/2 port.  ::) it now works
thanks anyway
