Author Topic: U360 and the shift key  (Read 1064 times)
hellothere123
  • Last login:March 02, 2021, 03:39:27 am
« on: August 02, 2007, 09:05:42 pm »
With the firmware upgrade, U360 has button 8 of 8 being a shift key. This allows 7 additional admin keys to be used when you hold down shift.
Question i had was, if I map 7 admin keys to Shift + Joystick #1, can I map different admin keys to Shift + Joysick #2?
i understand the drawback is moving from Joystick #1 to Joystick #2...but is it possible?
Jouster
  • Flap, Flap...Crash
Re: U360 and the shift key
« Reply #1 on: August 03, 2007, 11:42:50 am »
Well, the shift would only work with buttons...not the joystick itself.  (just making sure we're on the same page.)  Are you going to need more than 7 admin buttons?
If so, you could use the shift on the second joystick, and then the secondary button.
Jouster
