Author Topic: Wg monitor k7000 white screen  (Read 1829 times)
thunder-rolling
  • Last login:August 25, 2007, 06:23:47 pm
« on: July 31, 2007, 12:28:46 pm »
Hi,
I've set up this monitor. When I start it up, the screen is green, then changes to white.
Is there something I missed or is there something seriously wrong here?
grantspain
Re: Wg monitor k7000 white screen
« Reply #1 on: July 31, 2007, 02:31:44 pm »
what setup do you have,mame or arcade.
have you tested the voltages of the power supply?
is the game board/video source known good?
thunder-rolling
« Reply #2 on: July 31, 2007, 04:57:58 pm »
Hi,
Power source isolation transformer and JAMMA print were tested ok. I did this yesterday with an identical monitor (two out of one Final Lap cab) and all worked fine.
I did the wiring exactly the same, so the trouble must be with the monitor. The colour wires are setup right and the sync is set up the same as yesterday, so that should be fine too.
grantspain
« Reply #3 on: July 31, 2007, 05:21:31 pm »
maybe a broken trace or whatever i/c does the signal decoding,
thunder-rolling
« Reply #4 on: July 31, 2007, 05:23:43 pm »
Thanks alot. So a cap kit and checking for bad solder joints could be helpful?
grantspain
« Reply #5 on: July 31, 2007, 05:50:51 pm »
i guess so,but the fact you get a green screen then a white screen points towards more complex problems,can you make out any graphics during these screens-no matter how faint?
