Author Topic: +sens/-sens  (Read 1955 times)
arcadefever
  • Miami Beach Florida
+sens/-sens
« on: July 30, 2007, 12:31:03 pm »
hello,
i just need some help on the +sens/-sens found on some power supply...
if i use a regular power supply where the +/- sens need to be connected ?
ex: if i build a jamma loom for a atari system 1, the pinout say + sens then +5
or -sens then -15v
po1 power
http://www.jammaboards.com/pinouts/Atari%20System%201.txt
thanks
Level42
Re: +sens/-sens
« Reply #1 on: July 30, 2007, 02:14:08 pm »
Hey fever, aren't these the feedbacks that the power supply used to check the voltage and adjust if necessary. Think new switching power supplies don't want these connected....
Rocky
Re: +sens/-sens
« Reply #2 on: July 31, 2007, 09:01:30 am »
You don't have to connect the sense lines.  If you want to, you can connect them as follows:
+ sense = +5v
- sense = ground
Pac-Fan
  • Last login:February 05, 2014, 09:30:12 am
Re: +sens/-sens
« Reply #3 on: July 31, 2007, 09:43:51 am »
+ sense = +5v
- sense = ground
Some boards will *require* you to connect the sense lines in order to boot. I think Bally MCR boards are like this (e.g. Tron, Kickman, Tapper). But try it without connecting first and see if it boots.
arcadefever
Re: +sens/-sens
« Reply #4 on: July 31, 2007, 01:18:45 pm »
 :cheers: thanks a lot guys for the help !!!!
yes, some PCB require sens to be connected to boot properly.
Kevin Mullins
    • Me on Myspace
Re: +sens/-sens
« Reply #5 on: July 31, 2007, 10:50:48 pm »
You're correct.... the only purpose (in a round about way) is that the pcb knows that the voltage is there.
Kinda like the older Atari vectors that have sense lines on the ARII board.... it can be bypassed and the board will run fine.
Bypassing meaning -
+ sense = +5v
- sense = ground
Forgive me if my terminology is a bit off, but you should get the idea.
