Author Topic: relay help please!  (Read 2237 times)
icabjeff
  • Last login:May 10, 2009, 09:01:23 pm
relay help please!
« on: July 29, 2007, 01:17:51 pm »
I'm trying to use an electronic relay to be able to switch between up/down and left/right on an X-Arcade modified for disabled use. I want to be able to use a pair of  head switches and a separate switch operating the relay to use the directional controls on the X-Arcade. I'm not totally sure where exactly to solder the diode in the circuit to handle the electrical spike.
Jeff
BobA
  • What Me Worry?
Re: relay help please!
« Reply #1 on: July 29, 2007, 01:23:19 pm »
The band at the cathode end goes to the +v and the anode of the diode goes to gnd.   On an electroinic relay you should not need the transient supression as it is not an electromechanical and does not have the coil that generates the spike.  If you are using a solid state electronic relay you should check the specs and you will probably not need the supression diode.
icabjeff
« Reply #2 on: July 29, 2007, 05:50:36 pm »
I don't think it's electronic. I think it has a coil. Hear are the specs.
Relay - DIP
   •   Suitable for handling low signals in computer peripherals, telecommunications and security equipment.
   •   Standard DIP Package.
   •   Coil arrangement: 2 FORM C (DPDT).
   •   Capable of Switching Loads up to 2A.
Qty
          Nominal      Coil
           Coil     Resistance
Part No.  Voltage      +20%
22RZ5      5           45
BobA
  • What Me Worry?
« Reply #3 on: July 29, 2007, 06:37:41 pm »
Ok it has a coil so the proper location of the diode is shown in circuit diagram in the thread below you will be connecting to 5V to activate not 12 as shown in the diagram but the diode is still placed with cathode (band) to +5v and anode to ground for transient supression.
Link
« Last Edit: July 29, 2007, 06:40:29 pm by BobA »
icabjeff
« Reply #4 on: August 09, 2007, 01:52:24 pm »
Link
