Author Topic: Lexan - Other Names  (Read 3815 times)
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Lexan - Other Names
« on: April 25, 2003, 10:53:13 am »
I know this was asked 6 months ago but I lost the thread.  Does anyone know the other names lexan goes by?  I am having an extremely tough time finding lexan in Chicago.
Psyklops
  • Last login:June 17, 2003, 11:39:55 am
Re:Lexan - Other Names
« Reply #1 on: April 25, 2003, 11:07:15 am »
You shouldn't be having any problems... I can order it in and I live in a small town of 40,000 people in Northern Alberta, Canada.  Check with a glass shop instead of looking at the Home Depot type stores....
BobA
  • What Me Worry?
« Reply #2 on: April 25, 2003, 11:13:51 am »
I got mine at home depot where it came with the brand name Lucite-Tuf.  I think the chemical name is polycarbonate sheet.
BobA
Superdude
« Reply #3 on: April 25, 2003, 12:43:13 pm »
What department did you find Lucite-Tuf?
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #4 on: April 25, 2003, 12:49:53 pm »
I also used Lucite from Home Depot.  On my 2nd control panel build they didn't have a piece of Lucite large enough so i bought "Optix" instead.  They're basically the same thing as far as i can see.  Both of them drilled and routed about equally.  Ask someone in the store and i'm sure they can direct you to exactly where the stuff is located.  I paid under $20 for a sheet of Optix that was large enough for me to cut two 39x16 control panels and still have a lot left over.
BobA
  • What Me Worry?
« Reply #5 on: April 25, 2003, 01:28:08 pm »
It was at the back of the store where they sold the doors and windows.   Used to replace window glass and make it more burgular proof.
BobA
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: April 26, 2003, 10:39:13 am »
Technical name is polycarbonate sheet.  Home Depot also carries a product called Chrystallite, which is less expensive and should do the same things for an arcade cabinet.
