Author Topic: Any Alternative to the : Bits Limited "smart strip" that Home depot sells  (Read 3806 times)
mrclean
    • Guscade
looks exactly what I need does any local stores sell a similar product such as a local home depot?
2,370,650 Gun.Smoke
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
Sears has something like that intended to turn on a light or dust collection when a tool is turned on.  Not sure if the price is better (IIRC it's about $25).
IIRC, Cyberguys has a different model that does the same thing.
If I do not respond to your post in a timely manner, feel free to PM me.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
I considered one of these because it was a bit cheaper, but in the end I bought a BU SmartStrip and highly recommend it. I don't think HD carries an alternative.
-pmc
koz319
  • Last login:November 12, 2013, 12:13:45 pm
  • So much time, so little to do.
Here's a link to another thread referencing the Sears version ..
http://forum.arcadecontrols.com/index.php?topic=68046.msg693961#msg693961
Koz
Kaytrim
  • I'm too nice a guy
Here is one that you can use from NiceMite
Or if you want to hack your own look here.
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
While I have a smart strip in my cabinet now, I find it is very finiky on detecting the PC power. Depending on where I set the sensitivity, it either doesn't turn the monitor on, or doesn't turn it off. I've gotten to a point now where it will *eventually* turn it off (think hours), but its still frustrating.
Instead, I've decided to try a new computer PSU that an extra AC Outlet in in (Vantec 420 for the interested). The outlet in only energized when the PC is on, so it should do the trick (in my case, its only the monitor that I'm trying to sync power with the PC)...
I'll report back when I get it and get it installed.
severdhed
  • RIP Dinosaur Hippo
i am using the Sears/Craftsman unit and it works beautifully
mcfreak
  • Last login:March 01, 2021, 01:55:04 pm
  • Asteroids moving along...
    • Hobby Blog
Agreed on the Sears/Craftsman unit.  It works perfectly and if you want it instantly you can run down to Sears and get it now.
Disturbed013
  • Last login:December 28, 2007, 08:18:14 pm
  • Anybody can be a non-drunk.
Sears unit is going into my mame cab as well, just bought it last week.
Price here was $19.99 + tax.  Several were in stock.  Salespeople were useless, but I found them myself.
Double Diamond  100%
Spy Hunter II  98%
Mame Cab ~65%
rockin_rick
Here's the info on the sears unit.
Craftsman Auto Switch
Sears item #00924031000 Mfr. model #24031
I'd link to it, but IIRC sears's website is finicky...  One of those item#'s in their search box should find it.  (I found it with the search terms "dust switch")
I seen it in the store (my store anyway) near the clamps and sawhorses.... FWIW
moriartyds
  • Last login:November 05, 2007, 09:09:39 pm
I'm having a similar problem with my Smart Strip from Bits Unlimited.  It's very finicky re: when it turns things off.  Everything always boots up on command but half the time things don't shut down properly.  I'm still messing with the sensitivity hoping that will help.  If not I may check out this Sears option.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
I just purchased the PAM-102 Powerminder from Jay Kang. It's manufactured by Hobbes USA, and so far it looks to do everything the Smart Strip does, but at a MUCH cheaper price. You can probably find it at a lot of online shops, but Jay Kang was the cheapest at $24.95 that was in stock. The product I recieved was also in a rebranded box called "DataGuard Smart", so search around for that one too to find the same product.
Initial testing proves it works great. There's not much to say since it just turns stuff off and on based on the monitored outlet, but it does that perfectly so far. To hell with you Bits Ltd. and your overpriced product!
Guaranos
Oh yeah, well, my Smart Strip is haunted.  Every once in a while it will decide to turn on the monitor and marquee light when nobody is around.  Sometimes, if I wait outside the door to the game room, I can hear it flick on and off a couple of times.
mrclean
    • Guscade
Well thanks everyone for your replies and comments I ended up going with the sears unit and it's working great! no complaints so far .
2,370,650 Gun.Smoke
