Author Topic: Metal CP Question.  (Read 1546 times)
Kaytrim
  • I'm too nice a guy
Metal CP Question.
« on: July 23, 2007, 05:43:47 pm »
What type and thickness of metal is typically used for control panels?
TTFN :cheers:
NIVO
Re: Metal CP Question.
« Reply #1 on: July 23, 2007, 05:52:12 pm »
1/16" is more than strong enough to do the job, it is what i used on mine. It allows just enough material to countersink for the heads of machine screws, if you go this route for a smooth surface. And when using a 1 1/8" punch for joy/button holes, pretty much makes the panel perfect.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: July 23, 2007, 09:23:43 pm »
Most arcade were 1/16" AFAIK.  Derived from the fact that trackball's lip was 1/16" tall, and the few used CPs I have laying around.
Robin
Knowledge is Power
Apollo
    • Eight Bells
« Reply #3 on: July 23, 2007, 09:34:49 pm »
I use 2.5mm electro galv, it is very strong, fairly cheap, pretty easy to work with and it powder coats very well.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #4 on: July 23, 2007, 09:39:28 pm »
When I went shopping to buy sheet metal to make a new panel, I compared to an existing Ms Pac panel that I had. 16ga was dead-on. This is consistant with everyone else's estimates as it's somewhere around 1/16" thick. Almost all panels I've seen are plain steel. My Neo-Geo dedicated cabinet's a bit weird in that it has an aluminum CP.
