Author Topic: Happ 3" trackballs $68.59  (Read 4029 times)
Chris
    • Chris's MAME Cabinet
« on: April 24, 2003, 09:36:55 pm »
I just noticed that Happ has their 3" trackballs on sale for $68.59.  They normally go for $92.65!
http://www.happcontrols.com/wp/item_search.html?item-no=56-0100-11HL
I asked if the trackballs included the new "red" optic boards, and got an E-mail from Tom Happ confirming that they do.  The new optic boards have "improved circuitry to guarantee an optimized performance signal both at low and high rpm speeds", according to their site.  I'm guessing that this should reduce backspin even at fairly high speeds.
--Chris
« Last Edit: May 09, 2003, 12:05:36 am by Chris »
--Chris
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Happ 3" trackballs $68.59
« Reply #1 on: April 25, 2003, 02:29:34 am »
Good news! thanks for posting this.
hevnsnt
  • Last login:November 02, 2018, 10:26:57 am
  • Someone set us up the bomb!
    • I-hacked.com Taking Advantage of technology
« Reply #2 on: April 25, 2003, 09:14:06 am »
D@mnit!  I just paid $50 for a used one with old bearings.
Chris
« Reply #3 on: April 25, 2003, 09:22:32 am »
Oh, that sale ends at the end of April...
hevnsnt: I think I was in that auction with you.... :)
--Chris
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #4 on: April 25, 2003, 08:03:05 pm »
Hey!!!  My Happ order just shipped about a month ago and I just checked my 3" highball trackball.  It has green optic boards.  Should I be concerned?  I plan to play Golden-Tee with this.  When did they upgrade the optics?  Should mine have had red optic boards?
Best Kid iPad Apps
Chris
« Reply #5 on: April 25, 2003, 09:57:31 pm »
The Highball is a different part number, 56-0110-11, which is a general purpose trackball.  Part number 56-0100-11HL is described as "3" Diameter White High Lip Trackball For Use In Golden Tee
--Chris
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
« Reply #6 on: April 29, 2003, 01:09:46 pm »
OK, how would I hook this up to my PC for MAME??
Chris
« Reply #7 on: April 29, 2003, 01:54:16 pm »
Via an Opti-PAC, a Happs trackball USB interface, or a mouse hack (http://www.arcadecontrols.com/arcade_controls.shtml#happ2mouse).
--Chris
--Chris
Chris
« Reply #8 on: April 30, 2003, 01:06:49 am »
Okay, I'm probably the cheapest guy around here, and I tried three different PC trackballs before grudgingly buying the Happs...
I can now say I don't regret this expense for a second! Marble Madness is again a work of art rather than an excercise in frustration... I'm a lot more accurate at Shuffleshot... I can actually play Shuuz and American Horseshoes... and Golden Tee PC feels just like the arcade now!
I hacked one of those $3.99 translucent blue trackballs rather than pay $60 for the Happ interface... it works perfectly!  If you order this trackball and are planning to hack a mouse, make sure you also get part number 43-0456-00 (6-pin female Molex plug) and qty 10 of part number 43-0144-00 (female Molex pins); you'll need those to build the interface to the trackball.
--Chris
--Chris
Bill_S
  • aka buzzdalf
« Reply #9 on: April 30, 2003, 12:36:38 pm »
Anyone have instruction for how to do the mouse hack?  I have a cheap PC trackball right now and everyone (including me) complains about it when playing games with it.  I tried the link referenced above but the mamezilla link that follows doesn't appear to work.
I'm pretty cheap too, so hearing Chris say that really makes me think I should jump on this sale.
Chris
« Reply #10 on: April 30, 2003, 01:26:03 pm »
The hardest part of the mouse hack is finding a suitable mouse: ideally one with a ball (non-optical), no scroll wheel, non-Logitech, and both USB and PS/2 support.  Unfortunately, these don't seem to exist...
I also had trouble finding the mouse hacks, so I am halfway through writing a new one...
http://mamewah.mameworld.net/MouseHack.html has some info, but it gets its +5v from the computer, not the mouse...
There's another one at http://www.members.shaw.ca/bakaye/tballhack.htm, but with few pictures and it's a bit harder to follow...
--Chris
--Chris
Nikodemz
  • Last login:May 11, 2003, 05:25:37 pm
« Reply #11 on: May 01, 2003, 12:20:15 pm »
Chris
« Reply #12 on: May 01, 2003, 12:33:28 pm »
As I understand it, the high lip is designed to fit the latest Golden Tee panels specifically; if you add the extra plate, it should mount and play like the other 3" trackballs. In fact, if you look at the "regular" 3" balls, the white ball is no longer available; it redirects you to the Golden Tee ball.
More information on the spacer is at http://www.happcontrols.com/images/pdf/ins0060.pdf .
I'm not sure what games the High Ball is designed for; Missile Command or bowling games, perhaps?
--Chris
« Last Edit: May 01, 2003, 12:36:41 pm by Chris »
--Chris
Veto
  • Last login:May 21, 2003, 05:35:12 pm
  • GTG 3D in Mame soon please.
« Reply #13 on: May 01, 2003, 01:39:27 pm »
I think the highball is more suited for kiosks/ displays than for general gaming.  It would be fine for games where you are just scrolling around, but not when you want to take a big golf shot.  BTW is anyone running GT golf PC on win XP?  Doesn't work for me.
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
« Reply #14 on: May 01, 2003, 02:14:22 pm »
i got the high ball case so i can set the ball under my lexan.  Otherwise the regular ball is 2 low.
shmokes
    • Jake Moses
« Reply #15 on: May 01, 2003, 02:14:25 pm »
First place to go is right-click on the file used to load the program (gt.exe or something like that) and click properties.  Go to the "compatibility tab" at the top of the properties window and tell it to run in Windows 98 compatibility mode.  Surprisingly this works nearly all of the time.
Best Kid iPad Apps
Chris
« Reply #16 on: May 01, 2003, 02:18:28 pm »
I think the new high lip version will solve that problem as well.  At least I hope so...
--Chris
AX
« Reply #17 on: May 01, 2003, 02:35:31 pm »
yeah well I didn't feel the high lip would make the ball any higher.  I plan to file the lexan down around the edges to make is all silky and smooove.   this would make the high lip a little dumb for me.  might work ok for you if you want it to be flush.
Chris
« Reply #18 on: May 01, 2003, 02:43:51 pm »
This is how my PC ball is installed now.  Filing down that lexan is gonna be a pain in the butt, but it'll look great as long as you don't rush it!
--Chris
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #19 on: May 02, 2003, 05:03:10 am »
The highlip can make the ball higher above the plexi.
Without the spacer, you gain up to 1/8" more than the normal old-school happs/atari 3" TB, if the lip can go up into the hole in the plexi and the lip does not go above the top of the plexi.  So if you have 1/8" thick plexi, drill a 3" hole for the ball+lip, and countersink the mounting plate 1/16" input the wood, the ball would be exactly the same as if you had the normal TB mounted on a 1/16" metal-only CP.
The highball, on the other hand, seems to gain 3/8" more than the old school TB case, again, if the lip can go into the plexi but not above.  Three times more than the high lip over the normal, true, but more than needed in most situations IMO (not all, though).
* All measurements from top of case, but not including lip, to top of ball, minus 1/16" for a mounting plate (ie: happs mounting plate).  I have a highlip, comparing it against the normal and highball drawings at happs site.
Okay, one of the few cases that the highlip won't help. :P
(I'd prefer the lip flush with the top of the cp.)
FWIW, the happs lip is very nice, and better, IMO, than the betson or wico 3" TB lips.  You might be able to do better than it by filing the plexi, but I haven't found any filed plexi TB cp (found mostly in bars) that I'd want to play any games but golf or bowling.  The plexi's smooth and all, but my fingers would get sucked down between the ball and the plexi and either get pinched or stuck if I played missle command or cabal for instance.  (I play with my fingers on those types of games.)
My $0.02
Robin
Knowledge is Power
Chris
« Reply #20 on: May 09, 2003, 12:11:35 am »
By the way, it looks like Happ's extended this sale till the end of May...
For the interface, my local Staples has USB "E-Mail Mice" on clearance for $4.50... I bought one, should make a good hack platform.  (I built an interface out of the "$3.99 Translucent Trackball", but I'm making another one for a friend.)  Radio Shack has the 6-pin female Molex connectors with pins for $1.99, which is slightly cheaper than Happ.
--Chris
--Chris
