Author Topic: help with arcadeVGA  (Read 2323 times)
F_Zero45
  • Last login:July 15, 2013, 10:10:32 pm
help with arcadeVGA
« on: July 19, 2007, 04:34:43 pm »
I just hooked my new one up to my 25" standard resolution, wells gardner monitor (25K7193) and the screen is dark as hell. It's not a matter of adjusting the contrast or brightness. The colors are there but they are all soooo dark. I know it is not the monitor itself because I hooked it up to another one of my working monitors and same issue.
« Last Edit: July 19, 2007, 05:28:33 pm by F_Zero45 »
SirPeale
  • Green Mountain Man
Re: help with arcadeVGA
« Reply #1 on: July 19, 2007, 06:19:40 pm »
You probably need a video amp.
F_Zero45
« Reply #2 on: July 19, 2007, 06:55:45 pm »
how can i find out if my monitor needs this part before i spend money on it
grantspain
« Reply #3 on: July 19, 2007, 06:59:49 pm »
contact andy at www.ultimarc.com i am sure he will know which chassis require a signal amp
grantspain
« Reply #4 on: July 19, 2007, 07:04:12 pm »
Chris G
« Reply #5 on: July 20, 2007, 12:28:59 pm »
That sucks... I have a 25K7191 and it didn't need an amp... I thought most of the WG's didn't need one.
F_Zero45
« Reply #6 on: July 20, 2007, 01:29:21 pm »
here is a pic of the mame window. see how faded and colorless it looks. Like i said I know it is not the monitor because I hooked it up to one of my working game's monitor and it looks the same.
SirPeale
« Reply #7 on: July 20, 2007, 01:54:17 pm »
You mean you hooked the PC to another monitor and it looked the same?
Still gotta go with video amp.
F_Zero45
« Reply #8 on: July 20, 2007, 03:42:40 pm »
I hooked the pc , via arcadeVGA, to my mortal kombat's monitor and it still shows dark / faded colors.
SirPeale
« Reply #9 on: July 20, 2007, 05:43:14 pm »
and you hooked the PC up to another monitor with the same result?
F_Zero45
« Reply #10 on: July 22, 2007, 03:38:26 am »
Yes. I already talked with Andy and I'm just going to send it back to be replaced.
