Author Topic: How thick is the top of your console?  (Read 1506 times)
DinoRoger
  • Last login:October 24, 2005, 02:00:37 am
  • Hey, can I borrow a quarter?
« on: April 24, 2003, 06:39:37 pm »
What is a good sturdy but not to thick console height?  I tried a
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:How thick is the top of your console?
« Reply #1 on: April 24, 2003, 06:45:17 pm »
5/8 MDF with 1/8 Plexi or Lexan
I think sinking the joysticks is the best methiod. You could try 1/2" plywood and 1/8 Plexi... but most prefer the MDF and it's easy to work with.
paigeoliver
  • Awesome face!
« Reply #2 on: April 24, 2003, 07:28:01 pm »
I used sheet metal for mine, so it is probably like 1/16" thick. In the past I have used 1/2" plywood with good results. It kind of depends on your sticks. Some sticks do fine with inch thick panels, others pretty much have to go on a metal panel.
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
« Reply #3 on: April 24, 2003, 07:36:34 pm »
I use 3/4" MDF and it seems fine to me.  The happs joysticks can be adjusted for wood control panels, you know.  My CP is also covered with 1/8" lexan as well.
Moebius
  • Last login:June 18, 2003, 07:44:30 am
  • Thanks for the fish
« Reply #4 on: April 25, 2003, 08:03:31 am »
I wasn't aware of that. Could you give us a quick-heads-up on how the adjustments can be done?
paigeoliver
  • Awesome face!
« Reply #5 on: April 25, 2003, 08:08:09 am »
You can change the height of the joystick by switching around the order of the plastic parts that go around the shaft.
I used to have a pair of Happ sticks (still do somewhere), and I remember doing that. I eventually realized that all those Happ Sticks have a terrible feel, and instead started using older sticks that use a rubber return to center. They feel about 100 times better.
