Author Topic: where to get a lcd non wide screen for a jamma cabinet.  (Read 1467 times)
bigdaddynsir
  • Last login:July 28, 2007, 11:40:33 pm
« on: July 18, 2007, 10:52:33 am »
would like to stick a non lcd in a jamma cabinet with the 60 n 1 board.  most of the ones i have found so far have been wide screen. any suggestions or anything else that some one has used. a 19 inch looks to small for the cabinet. thanks
Thread Killer
  • Last login:March 26, 2008, 12:24:13 am
Re: where to get a lcd non wide screen for a jamma cabinet.
« Reply #1 on: July 24, 2007, 08:32:29 pm »
I second that emotion. Does anyone manufacture a 24.8/25" 4:3 LCD? Is there enough demand to create one?
My cab has a TV that obstructs the back door, which takes away all of the authenticity. I want an actual monitor, but not an 80-lb one that delivers lethal voltage.
« Last Edit: July 24, 2007, 08:36:28 pm by Thread Killer »
Nocturnaloner
  • Last login:May 05, 2016, 12:39:53 pm
  • AARRRRcade!
« Reply #2 on: July 27, 2007, 09:36:39 am »
I'd like to know as well.  I see that 21" (21.3) 3:4 monitors are pretty widely available, and fairly inexpensive.
bigdaddynsir
« Reply #3 on: July 28, 2007, 11:36:03 pm »
i usually go to slickdeals.net           or           xpbargains.com          for lcd screens. but the only problem is that most of them now are wide screen only. the only way to rotate the picture is with a computer hard drive and also a driver to let the monitor know that it needs to rotate 90 degrees.
