Author Topic: Arkanoid spinner lube advice  (Read 2923 times)
sosuke
  • Last login:September 28, 2016, 06:29:08 am
« on: July 14, 2007, 10:01:24 am »
I recently got an original Arkanoid spinner off ebay. I'm wonder what the best type of lube would be to use on it? I'm thinking about using silicon, as I'm guessing anything oil based will probably do some damage to the plastic gears(?) Any suggestions on what lube I should use would be appreciated.
Thanks.
SirPeale
  • Green Mountain Man
Re: Arkanoid spinner lube advice
« Reply #1 on: July 14, 2007, 12:15:47 pm »
I recently did something similar.  You could use white lithium grease.  I didn't have any, so I used some petroleum jelly.  Shouldn't break down.
sosuke
« Reply #2 on: July 14, 2007, 12:21:28 pm »
Thanks, I completely forgot about white lithium grease. I'll give that a try. Hopefully it'll cut down on the vibrations when I spin it, but I get the feeling something might be slightly bent and need to be replaced. Oh well that's the fun of all this right?
Edit:
white lithium grease is where it's at. Spinner is super smooth now, no grinding or nasty vibrations. Encoder wheel looks a little bent but that's a whole other problem to deal with.
« Last Edit: July 14, 2007, 03:31:58 pm by sosuke »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: July 16, 2007, 03:57:57 pm »
IIRC, the manual recommends white lithium grease.  Good call! :D
Robin
Knowledge is Power
northerngames
  • Trade Count: (+18)
« Reply #4 on: July 17, 2007, 04:13:08 pm »
I know you fixed it already but for other that dont have any of the white lithium hair clipper oil works also and works good on alot of things lol.
sosuke
« Reply #5 on: July 17, 2007, 06:34:14 pm »
One thing I'll say about white lithium grease, make sure you use it where you don't mind making a mess. It doesn't really come out of the can in a consistent way (at least not until you use it a while...) So don't use it on your kitchen table (unless it's the one you solder on and never use for eating...)
