Author Topic: Atari 2600 Emu w/ key config  (Read 1479 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: July 12, 2007, 12:08:48 pm »
Anyone know of an Atari 2600 Emu with a Key config to change the button????????
unclet
Re: Atari 2600 Emu w/ key config
« Reply #1 on: July 12, 2007, 12:27:38 pm »
I would state that the most popular Atari2600 emulators are "stella" and "z26".  not sure what you are looking for regarding the "key config to change the button" statement you made   :dunno
Chunce DeLeone
« Reply #2 on: July 12, 2007, 03:15:27 pm »
Just want to change the Player one button 1 to a different key, rather than spacebar, so it works with my cab,  niether of those programs have that option
unclet
« Reply #3 on: July 12, 2007, 04:45:36 pm »
I just downloaded the latest "stable release" of the stella emulator (ie: stella-2.3.5-win32.zip) from here:
   http://stella.sourceforge.net/
Once you unZip it you will see a "Docs" directory which has an index.html file located inside.  View this HTML page and then read section 8 (Keyboard Layout) and then section 9 (Event Remapping).  I believe section 9 will allow you to remap the keys to how you want them.
Just double-click the "stella.exe" which should result in a window popping up.  Click "Options", click "Input Settings" and then scroll down to "P0 Joystick Fire" (for some reason player1=P0 and player2=P1).   Anyway, you can change the key mapping there if you want it to be something else.
** Actually it seems the default key mapping for P0 Joystick Fire is "SpaceBar" or "LCtrl" already, so if you can simply use LCtrl you might not need to reset any key mappings then.
Anyway, stella is pretty powerful.   A lot of nice options in the index.html file you should read through if you to tweak stuff .
Good luck
« Last Edit: July 12, 2007, 05:01:47 pm by unclet »
Chunce DeLeone
« Reply #4 on: July 13, 2007, 09:10:06 am »
Don't know how I missed that one,  The Stella Version I have didn't have that option,  Thanks
