Author Topic: Width Coil Problem  (Read 1143 times)
Solvalou
  • Last login:September 06, 2007, 01:25:08 pm
Width Coil Problem
« on: July 10, 2007, 09:38:51 am »
Hi!
I got a Electrohome G07 19".
If I twist the screw of my with coil nothing on screen changes. Should it regulate the size or what?
The PCB sends a comp Sync Signal, but my screen supports only VSync and HSync, or Negative V- and HSync.
So I decidet to put a Bridge on the connector between V- and Hsync, the picture is perfect!
But the size and the position isnt correct. Can I do it a other way?
Thanks for your help!
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
Re: Width Coil Problem
« Reply #1 on: July 10, 2007, 03:30:36 pm »
the width coil on a g07 does very little as far adjusting the size I have found.  A 1/2" at most
will be gained or lost with it.  You can however get Bob Roberts horizontal width kits ....
http://therealbobroberts.net/width.html
all the info is in the link...
hope this helps
