Author Topic: Component Dvi problem scrambled image  (Read 1470 times)
churchpunk1123
  • Last login:September 19, 2009, 01:38:26 am
« on: July 10, 2007, 02:20:39 am »
Hey,
  I have an ATI Radion 9250 and am using a DVI to Component dongle to a TV with 480i.  The image gets scrambled and the colors are strange.  I can hardly see the image of the windows booting up.  S-video works fine.  Does anyone know how to fix this. PLEASE HELP
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: Component Dvi problem scrambled image
« Reply #1 on: July 10, 2007, 04:45:23 am »
Does the card support component out via the DVI connector? You will get crazy colors that dont sync if you feed rgb into a component input since in vga mode he sync is on a seperate pin. I have seen a generic dvi to componant cable that would not work on a video card, it was only suitable for a DVD player which had a menu to change to component on the DVI socket on it.
BobA
  • What Me Worry?
« Reply #2 on: July 10, 2007, 08:06:13 am »
I do not see the 9250 in the list of cards that work with the DVI to component adapter.
The DVI-to-HDTV adapter can be used to drive YPrPb component output for direct drive of HDTV displays. It can be used for the following graphics board series:
    * ALL-IN-WONDER RADEON 8500 Series
    * RADEON 9500 Series
    * RADEON 9600 Series
    * RADEON 9600 PRO PC & MAC Edition (Compatible with PC users only)
    * RADEON 9700 Series
    * RADEON 9800 Series
    * RADEON X800 Series
    * RADEON X850 Series
    * RADEON X1K Series
    * RADEON HD 2000 Series
Justin Z
  • Last login:December 18, 2025, 09:47:41 am
« Reply #3 on: July 10, 2007, 08:28:34 am »
Yup, that's the problem.
I upgraded my 9250 to a 9550 in order to be able to use the dongle.  You'll have to do something similar.
Green Giant
« Reply #4 on: July 10, 2007, 02:51:23 pm »
Just to clarify.  Are you having problems seeing windows once its booted or while it is booting.
With another monitor, have you set the computer to 640 x 480.  You will see windows once it boots but doubtful you will see anything until windows boots up.
Toxic Arcade, my first build
