Author Topic: ZSNES, remapping exit key and other issues  (Read 3557 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: July 04, 2007, 07:09:18 pm »
How can I remap the exit key in ZSNES to use the esc key?
« Last Edit: July 04, 2007, 10:34:31 pm by squirrellydw »
I b**ch. People listen!!
unclet
Re: ZSNES, remapping exit key
« Reply #1 on: July 04, 2007, 07:14:40 pm »
If you double-click "zsnesw.exe", then the program should start and place you in a menu.  I believe you can go into the Misc/Game Keys menu and set the EXIT key mapping.
squirrellydw
« Reply #2 on: July 04, 2007, 07:16:47 pm »
right but you can't use the esc key in there.  I think  ihave to do it through the file itself but don't know how
squirrellydw
« Last Edit: July 04, 2007, 07:35:02 pm by squirrellydw »
squirrellydw
« Reply #4 on: July 04, 2007, 10:22:23 pm »
OK where can i find UncleT’s instructions on setting up Zsnes?  It works fine by itself but I can't seem to get it to work from MaLa.  I also could use some help with Fusion for sega and Z26 for atari.
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
Re: ZSNES, remapping exit key and other issues
« Reply #5 on: July 05, 2007, 02:16:49 am »
You can find UncleT's instructions for MaLa here:
http://mala.arcadezentrum.com/help.html
Direct link:
http://mala.arcadezentrum.com/easytrack.php?id=emuguide
You can also try to use the MaLa Hotkeys to remap your ESC to the key needed by ZNES.
Or remap ESC to ALT + F4 to close ZNES.
http://mala.arcadezentrum.com/hotkeys.html
« Last Edit: July 05, 2007, 03:30:49 am by swindus »
unclet
« Reply #6 on: July 05, 2007, 07:13:20 am »
Thanks swindus   :)
Hey swindus,  you might want to link to the document directly in case I update it with some corrections.   I believe you have v1.3 and v1.4 currently exists:
http://unclet.arcadecontrols.com/MalaInfo/MalaEmuSetup-HowTo.doc
« Last Edit: July 05, 2007, 07:16:58 am by unclet »
squirrellydw
« Reply #7 on: July 05, 2007, 09:14:02 am »
thanks, looks like I might have to reorganize some files and paths, oh well
Green Giant
« Reply #8 on: July 05, 2007, 02:27:07 pm »
Try this out.
First set everything up with the controls how you like it.
Then open up zsnesw.cfg
Change guioff=0 to 1.
; -- GUI --
; Disable GUI (0 = NO, 1 = Yes)
guioff=1
This should cause it to exit the game to mala skipping the gui.
Toxic Arcade, my first build
squirrellydw
« Reply #9 on: July 05, 2007, 03:01:25 pm »
I found out its a bug in the latest mala RC9 beta, hopefully it will be fixed soon.
EDIT.....the bug in maLa has been fixed
« Last Edit: July 06, 2007, 04:31:23 pm by squirrellydw »
