Author Topic: 12v power question with PIC  (Read 1133 times)
urbecrisch
  • Last login:March 30, 2025, 01:11:38 pm
  • I was the S**T back in '82
« on: July 04, 2007, 10:57:29 am »
I'm curious if I can use my PC to power up my coin lamps (LED) or if I should use my power supply powering my arcade monitor.
I already have 12v power from my PC to my trackball (Lightmite).  Can I split the same wire to power my coin lamps or should I use the 12v coming from my external power supply (PIC1)?
I just don't want to damage anything giving too much juice from the same source.
Kevin Mullins
    • Me on Myspace
Re: 12v power question with PIC
« Reply #1 on: July 04, 2007, 11:37:47 am »
Yes
Yes
Especially if you're running LED's....they won't draw too much current off the PC power supply.
Just be sure to use the right voltage lamp/LED for whatever voltage you put to them.
i.e. 5v or 12v, etc
