Author Topic: MaLa, cocktail mode, flipping lists, not working?  (Read 5585 times)
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« on: July 01, 2007, 09:49:53 pm »
Just a quick question:
I'm setting up vertical cocktail machine, running MaLa RC9.  I'm under the impression that it is capable of auto-switching the game list view depending on if someone sitting on player 1 or player 2's side is operating the joystick.
I have 2 Ultrastick 360's wired in through USB, and MaLa isn't doing any switching at all, despite having both joysticks enabled in MaLa and a "set" for each of them.  I've configured player 1 to use set 1 and player 2 to use set 2, but no list-flips are happening.
Does anyone have this feature working, and if so, can you send me your .ini file so I can try it on my machine?
thanks,
-jeff!
loadman
  • Moderator
    • MaLa
Re: MaLa, cocktail mode, flipping lists, not working?
« Reply #1 on: July 01, 2007, 11:42:22 pm »
Ohh I don't have any USB joysticks to test this  :(
maybe you could change your posting subject to include Ultrasticks in the hope that you may get another U360 owner to try it  :dunno
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #2 on: July 02, 2007, 07:16:23 am »
On the cocktail mapping page select Joy 1 and Joy 2, not Set 1 and Set 2. Then it should work.
NOP
    • winterMAME
« Reply #3 on: July 02, 2007, 09:56:52 am »
That's one of the things I don't quite understand-on RC9, there is no "cocktail mapping page", as I've seen on lots of the configuration setup screenshots.
I have this configuration page:
http://wiki.arcadecontrols.com/wiki/Image:Mala_OptionsCMA.JPG
and not the screens from here:
http://mala.arcadezentrum.com/controllerdetection.html
The "controller mapping" page only allows sets to be selected, not joysticks.
I was wondering if that cocktail mapping stuff was from a previous release?  I couldn't find any older versions of mala to verify that, as it looks like it's exactly what I needed.
thanks for stepping in to help!
-jeff!
swindus
« Reply #4 on: July 02, 2007, 10:28:07 am »
Thats the right page and it is available in RC9. It was renamed from 'cocktail mapping'  to 'controller mapping'. Here is a picture of my dialog:
« Last Edit: July 02, 2007, 10:30:38 am by swindus »
NOP
    • winterMAME
« Reply #5 on: July 02, 2007, 10:51:48 am »
ok, still having problems.
I have 2 USB Ultrastik 360s.  They both have separate IDs.  Games work perfectly with them.
In Mala, under joystick, I have both joysticks enabled (checkboxes).
For both sets, basic and advanced settings are the same, except for J1up/down and J2up/down differences for scrolling through the list.
Under advanced, I have nothing set for any of the fields.
Under controller mapping, I have the left side player using Joy 2, and the right side player using Joy 1.
Use mapping checkbox is set.
When scrolling through the list, J1 side seems to work as expected.
Pressing J2 does nothing.  No flips, no list +/- nothing.
When I go back into options, and under the joystick check tab, J1 is visible, J2 is grayed out.  I move J1 around and see it respond.  If I switch the Set to 2, the screen doesn't change, but if I move J2 around, I see it respond in the J1 viewer.  Is that the crux of my problem?  MaLa is seeing my J2 as J1?
thanks,
-jeff!
« Last Edit: July 02, 2007, 06:31:18 pm by NOP »
NOP
    • winterMAME
« Reply #6 on: July 02, 2007, 08:25:32 pm »
another minor update: the screen saver does shut off if I use J2, so mala does recognize that it's moving...
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #7 on: July 02, 2007, 08:29:10 pm »
make sure one (joy2) isn't using a shift key.  it will show a different color, blue I think
I b**ch. People listen!!
NOP
    • winterMAME
« Reply #8 on: July 03, 2007, 12:16:33 am »
alas, no shifts defined anywhere on any screen.
perhaps I need to post a series of screenshots of my config?
swindus
« Reply #9 on: July 03, 2007, 02:23:14 am »
I think I know what the problem is. MaLa supports 2 joys and one pov per joystick set (for example on gamepads). So be sure you use J1 up and down in every joystick set for the movement.
Joystick Set 1
One up: J1up
One down: J1down
Joystick Set 2
One up: J1up
One down: J1down
and not: J2up and J2 down. <- This is the second joystick and the same joy controller and the U360 has only one joystick .....
Try this please.
NOP
    • winterMAME
« Reply #10 on: July 04, 2007, 12:54:11 pm »
That was exactly the problem.
wow.  whew even.  (I'm having a party tonight and that was one of the things I really wanted to get working)
Thank you very, very much for getting me through that.
-jeff!
swindus
« Reply #11 on: July 04, 2007, 01:12:01 pm »
Have a nice party!  :cheers:
loadman
  • Moderator
    • MaLa
« Reply #12 on: July 04, 2007, 07:15:29 pm »
I will put that in the Wiki as I'm sure that has been asked before....
LINK
« Last Edit: July 04, 2007, 07:20:04 pm by loadman »
