Author Topic: Ultimarc 2.25" Trackball  (Read 2755 times)
Zeno
  • Last login:May 12, 2009, 11:22:33 pm
  • Movement is an illusion
« on: July 01, 2007, 07:10:48 pm »
Does anyone know how I can "boost" my Ultimarc 2.25 TB?
This this is very stiff and just doesn't roll like I expected.  Anyone else have this issue, or is it my TB?
Zeno
Running: MAME
Projects: MK3, Ms. Pacman
NightGod
Re: Ultimarc 2.25" Trackball
« Reply #1 on: July 01, 2007, 07:44:12 pm »
Simple answer - use it.
They come stiff like that from the factory, it's from the thick grease they use on the bearings. I used to sit it on my desk/lap and spin it while I was watching movies, after a few hours of playing with it, it loosened right up.
Level42
« Reply #2 on: July 02, 2007, 01:21:59 am »
Yeah. And some people speed this up by running the bearings with a power drill for a while.....can't remember where I read that though, was it at Bob Robert's site ?
By the way, Ultimarc's 2.25" is a Suzo.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: July 02, 2007, 03:19:45 pm »
If you remove the top and lift out the ball and bearings, you can soak the bearings in WD40 for a while. That does the trick.
Andy
Zeno
« Reply #4 on: July 02, 2007, 03:37:34 pm »
Thanks Andy!
Keep up the good work.
Your customer service has been top notch.
Zeno
Running: MAME
Level42
« Reply #5 on: July 02, 2007, 05:12:44 pm »
Andy
Hey that's a great idea.... gonna have to do that with mine...if I ever get the time to install it :S
As I've experienced myself, Andy's service is  a great example for some other companies in this business.  :applaud:
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: July 02, 2007, 05:23:07 pm »
... you can soak the bearings in WD40 for a while....
And then you should re-grease them.  WD-40 dries up (it's designed to) and then the bearings wear fast.  Or you could re-WD-40 it about once a month, yeck.  And WD-40 can eat the plastic case, putting the bearings and rollers out of wack.
Use a nice (plastic safe) white lithium grease after letting the WD-40 dry, and you're good to go.  Or forget the WD-40 and just spin the bearings in the first place.  (Although if you use a high quality grease it could be better the the stuff that the bearings come with; then you should WD-40 and regrease).
Note: take my post with a grain of salt.  WD-40: you either love it, hate it, or don't know about it.  I avoid it except for special cases.  Others use it all the time for everything and they need to with it drying out and all, but anyways.  [shrug]
Besides the WD-40 thing, Andy's a great guy. ;)
Robin
Knowledge is Power
Kaytrim
  • I'm too nice a guy
« Reply #7 on: July 02, 2007, 05:34:37 pm »
I use TriFlow instead of grease.  It dosen't dry out like WD40 and it slicker than grease.  It is also safe on plastic.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: July 03, 2007, 12:26:29 pm »
Which TriFlow brand lubricant?  They have Red grease, synthetic grease, dry, a couple degreasers, and more.  I'm sure you don't mean either of the the degreasers, but besides that... :dunno.  From looking at their web site, I'd use TriFlow's synthetic grease, but you said "...instead of grease"... ???
Robin
Knowledge is Power
Kaytrim
« Reply #9 on: July 03, 2007, 12:38:24 pm »
I use the Superior Lubricant Aerosol spray.  The bearings roll nice, quiet and quick after a drop or two of this stuff.  I have also used it on old cooling fans that are sluggish.  After a drop or two on the bearing and a quick hand spin the fans have started working again quieter than ever.
TTFN
solid187
  • Last login:March 22, 2021, 02:55:43 pm
« Reply #10 on: July 12, 2007, 02:24:50 pm »
I use KY.  It's gentler on my balls.
