Author Topic: Suggestions for TV as monitor  (Read 3726 times)
HeadRusch
  • Last login:September 02, 2006, 04:13:30 pm
  • ....Here you are all EQUALLY WORTHLESS...
« on: April 22, 2003, 09:40:07 am »
My Cab, after removing some supports which were left there for the use of a standard monitor, now has a little more internal space.  I think a 25" TV would fill it nicely, but I have to check the dimensions on the case...also, I need to find one whos back doesn't protrude out five feet :P
Any suggestions?
".....its like a Koala crapped a rainbow in my brain!"
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:Suggestions for TV as monitor
« Reply #1 on: April 22, 2003, 02:54:03 pm »
People tend to prefer Toshiba's. Stay away from Apex.  Use S-video.  bestbuy.com gives the dimensions of their TV's.
Justin
  • Last login:November 25, 2025, 10:20:05 pm
    • Centipede MAME cabinet
« Reply #2 on: April 22, 2003, 09:38:11 pm »
What's wrong with the Apex?  They're cheap...  and probably crappy construction quality and cheap components (true?)    Is the Video quality bad?
"3 warps to Uranus" -- so I stopped playing!
Lilwolf
« Reply #3 on: April 22, 2003, 10:02:21 pm »
The quality on some are MUCH better then others.
1st, I've heard that some TV's with SVid just have a SVid -> Composite converter inside.
But if you are going to try a TV, make sure there is a return policy.  So go to a store like best buy where the people in the return department don't care if you return something or not.
Or if you go to a smaller local store.  Ask if you can bring a computer in and test it.  (some will)
Nothing like getting it home, installed, remove the cover and warranty... and find that it sucks
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #4 on: April 22, 2003, 10:53:56 pm »
Check out the Monitor/Video Forum:
http://www.arcadecontrols.org/yabbse/index.php?board=4
I have a JVC that works great with S-Video.  I'm working on getting component connections working at an acceptable resolution.  At 25", you probably wouldn't be able to find component, so you should go with S-Video.
One of the things you want is if you pull the power on the TV and then plug it back in, you want to make sure that the TV comes back on in S-Video mode.  The entire line of Apex TVs don't meet this requirement, so I stopped looking at them.  Toshiba and JVC both work good.
This opinion was created from 100% post consumed information.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #5 on: April 22, 2003, 11:36:30 pm »
Seconded.
paigeoliver
  • Awesome face!
« Reply #6 on: April 23, 2003, 12:45:33 am »
If you get a TV with a tube the same size as common arcade monitors, than your tube will bolt right into a frame made for those montitors. My Artic Mini MAME originally had the tube bolted right into the cab (frameless). My 19" s-video monitor tube bolted right up to the same spot, and I put the monitor boards on the wall of the cab where the original ones were. It looks PERFECT. Exactly like the original monitor did.
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #7 on: April 23, 2003, 01:31:13 pm »
Bad is not the right word.  i originally planned on using a 24-25" TV for my cab monitor.  I picked up one of the 24" Apex's from Circuit City for <$200 and put it in my cab.  I think i played Centipede for all of 3 minutes before i turned everything off and packed that sucker back up.  I was using the S-Vid input and it looked horrible.  Stay far, far away from Apex.
PS> I ended up using a 21" Viewsonic PC monitor for my cab instead and am very happy with my decision.
Distortion
  • Last login:June 10, 2016, 04:39:20 pm
  • Saints Row 2, Sucka
    • Volition
« Reply #8 on: April 23, 2003, 01:35:03 pm »
they're cheap, yes, but don't last long.  the colors tend to fade and the tint gets all messed up in time...
also, stay away from KLH....Daewoo and Sansui would be alright, but I'd trust JVC, Panasonic, Sony and especially Toshiba much more than those two.  Mine's a Toshiba.
Game programmers do not play games for a living.  Would you say a mechanic drives cars for a living?
JamesMolloy
  • Last login:November 12, 2003, 04:03:38 pm
« Reply #9 on: April 23, 2003, 02:11:28 pm »
How are Black Diamond/Midsubishi TV's? They are pretty cheap where I've looked.
caykroyd
  • Last login:March 07, 2007, 06:53:45 pm
« Reply #10 on: April 23, 2003, 02:22:01 pm »
mitsubishi's are arguebly the best rear projection tv's on the market, but not sure about regular tube.  And inexpensive?  not sure about that either.
CitznFish
« Reply #11 on: April 23, 2003, 03:41:55 pm »
Also, with APEX if you shut the TV off and turn it back on it will not restart in S-video mode. This really sucks if you have a TV in your cab.  Toshiba's remember thei S-Video mode even if you pull the plug out of the wall while the TV is on, wait 20 minutes and plug it back in.   (BestBuy guys were giving me wierd looks when i did this) ;)
radiator
  • Last login:April 18, 2013, 07:14:43 pm
  • SFA OK!
    • :: verticalcircle ::
« Reply #12 on: April 23, 2003, 04:14:50 pm »
When the Germans bombed the British, the British ducked.
When the British bombed the Germans, the Germans ducked.
When the Americans started bombing, everyone ducked!
