Author Topic: more coin mech help needed  (Read 2072 times)
sanbagger11
  • Last login:September 14, 2009, 05:38:24 pm
« on: June 26, 2007, 02:27:09 pm »
Hi
 I finally purchased a coin mech for my touchscreen jukebox and now have not a clue how to wire  it. It has 3 prongs at the bottom Im guessing to wire to. Can I use my computer power supply? And what wires go where?The one I bought is at this address http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=008&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=180129953283&rd=1&rd=1
Thanks for any help available
northerngames
  • Trade Count: (+18)
Re: more coin mech help needed
« Reply #1 on: June 26, 2007, 07:15:48 pm »
the lamp in it is a 12v it says when usually they are a 5 but if it is 12v then the yellow wire on your pc's power supply molex is a 12v and if it is a 5v then you would need to use a red wire instead of the yellow.
as for your coin mech switch's the outer post that is single and not alighned like the other 2 is the ground and the center post of the 3 is were your signal/+ goes
dunno what your using to interface the switchs with the pc though till you explain how your planning that.
shardian
« Reply #2 on: June 28, 2007, 11:11:49 am »
FYI, that mech has a very involved cutout. Refer to the following link for cutout detail.
http://www.happcontrols.com/coindoors/40002300p_exploded.htm
