Author Topic: am I missing something?  (Read 1319 times)
krazy_kenny1
  • Last login:May 20, 2011, 11:14:32 am
« on: June 26, 2007, 12:14:37 am »
I'm still kind of confused on how to configure mame with my TV connected using a DVI to component adapter.  Here's my current mame.ini
# <UNADORNED0>            <NULL> (not set)
# CORE SEARCH PATH OPTIONS
rompath                   roms
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE FILENAME OPTIONS
cheat_file                cheat.dat
# CORE STATE/PLAYBACK OPTIONS
# state                   <NULL> (not set)
autosave                  0
# playback                <NULL> (not set)
# record                  <NULL> (not set)
# mngwrite                <NULL> (not set)
# wavwrite                <NULL> (not set)
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             0
use_overlays              0
use_bezels                0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
# ctrlr                   <NULL> (not set)
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
# CORE MISC OPTIONS
bios                      default
cheat                     0
skip_gameinfo             1
# DEBUGGING OPTIONS
oslog                     0
# WINDOWS PERFORMANCE OPTIONS
priority                  1
multithreading            1
# WINDOWS VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  0
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                640x432@30
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             1
# INPUT DEVICE OPTIONS
mouse                     1
joystick                  1
lightgun                  0
dual_lightgun             0
offscreen_reload          0
steadykey                 0
joy_deadzone              0.3
joy_saturation            0.85
digital                   none
# AUTOMATIC DEVICE SELECTION OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
# CORE COMMANDS
# CONFIGURATION COMMANDS
# FRONTEND COMMANDS
# CONFIGURATION OPTIONS
readconfig                1
I keep hearing people saying to disable hwstretch, but if I do that, the game doesn't fill the screen since I have my resolution set to 640x432.  I also tried installing soft-15hz and setting the resolution to auto, but the TV didn't appear to support whatever resolution mame was trying to set it to.  Right now, text is a little blurry which I'm assuming is due to hwstretch.  How is everyone else setting up mame with their component-connected TVs?  Thanks.
