Author Topic: Remove Loading Profile Screen, Mouse and Boot Logo In XP??  (Read 2817 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: April 21, 2003, 07:30:58 pm »
Hi,
I managed to remove the welcome screen, and auto logon in xp. But I still have a blue screen appear that says "Loading Profile Settings" is there a way to hide this? is there a way to turn it off so it doesn't show?
Also the black screen that says loading xp can i remove it?
and the mouse and taskbar that pops on for a split second before lazarus loads can it be removed?
Thanks in advance
JIM
Demon-Seed
Re:Remove Loading Profile Screen, Mouse and Boot Logo In XP??
« Reply #1 on: April 21, 2003, 07:33:57 pm »
I see a few proggs on the site for boot logo which is the easiest to use?
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
« Reply #2 on: April 21, 2003, 08:20:20 pm »
Boot XP will allow you to change the XP boot screen to something more appropriate (i use the Atari emblem myself).  Basically, you have to hack the Windows kernel file.
If you go to Control Panel and change the way that users log on you will not only never see the logon screens, but the machine should start slightly faster as well.
I don't know of any way to get rid of the taskbar/mouse in XP.  In Win9X operating systems you could just change the shell, but XP doesn't like that very much.
You'll probably also notice the blue shutdown screen in XP.  I don't know of any way to get rid of that one either.
BASSOFeeSH
  • Last login:May 29, 2009, 12:46:42 am
  • TD-2779
    • Trooper Armor
« Reply #3 on: April 22, 2003, 12:26:03 pm »
You can auto-hide the taskbar, but I'm not sure if it will still how on startup.  I know mine does, but I have my quick-launch full of apps.
Also, X-setup(a low level tweaking utility you can grab from download.com) may have a way to edit some of these things.
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #4 on: April 22, 2003, 01:00:13 pm »
you can make a new cursor for you mouse that is blank.  that way you will never see it - booting up, shuting down, or even if you want to to see it.   ;)
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #5 on: April 23, 2003, 09:40:58 pm »
I use a program called hideshel.exe which I put in the startup group. It hides the taskbar ,all icons on the desktop
and disables the right click context menu on the desktop.
I downloaded it from a link on one of the examples websites. Maybe someone else has more info on it.
                                        Slug54
