Author Topic: Where to get a vertical monitor for a nintendo cab??  (Read 1905 times)
swolgam
  • Last login:April 26, 2010, 07:58:51 am
« on: June 16, 2007, 01:46:55 pm »
Need to know the best place to get a vertical monitor for a nintendo cab.
THanks,
Steve
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
Re: Where to get a vertical monitor for a nintendo cab??
« Reply #1 on: June 16, 2007, 02:03:36 pm »
I dunno about the best place, but there are a couple of options.
First off, I am going to presume that you want a Nintendo-compatible monitor because you are restoring a Donkey Kong or other Nintendo game using inverted video. If you are going to MAME it or put a non-Nintendo game in, the options are different and more plentiful.
Used EZ-20 monitors aren't too hard to find (RGVAC or eBay, etc) and I have had good luck with them. Bob Roberts, ArcadeShop and others usually have spare flybacks and cap kits if you need to fix it up.
If you want a new monitor to use with Donkey Kong, ArcadeShop has a converter board that is plug-and-play with a Vision Pro monitor (which they also sell).
Info for Bob Roberts (aka The Real Bob Roberts) and ArcadeShop can be found in the vendors section of the BYOAC wiki:
http://wiki.arcadecontrols.com/wiki/Vendors
Cheers
Working: Not Enough
Projects: Too Many
Progress: None
BobA
  • What Me Worry?
« Reply #2 on: June 16, 2007, 03:19:25 pm »
If you are using a 48 in 1 board then you need a standard arcade monitor not one made for nintendo.  Only need a nintendo compatable one if you are using a DK or DK Jr etc pc board.
swolgam
« Reply #3 on: June 16, 2007, 04:16:17 pm »
Probably going to go 48 to 1
CheffoJeffo
« Reply #4 on: June 16, 2007, 04:18:49 pm »
Then ignore everything I said ...  ;)
Working: Not Enough
Projects: Too Many
Progress: None
NoOne=NBA=
« Reply #5 on: June 16, 2007, 05:28:56 pm »
We usually do.  :laugh2:
Apollo
    • Eight Bells
« Reply #6 on: June 17, 2007, 05:11:47 pm »
oh man burn
Ken Layton
  • Guru
  • Technician
« Reply #7 on: June 17, 2007, 06:49:03 pm »
Don't forget that the Nintendo cabinet only supplies 100 volts to power the monitor.
You'll need a monitor with a built-in switching power supply section since those types will operate properly with 100 volts coming in.
shorthair
« Reply #8 on: June 18, 2007, 01:56:48 pm »
Check B/S/T.
