Author Topic: Wei Ya E0007 chassis working (checked), but still blank screen  (Read 2991 times)
littlemave
  • Last login:July 21, 2007, 04:40:45 am
My faulty Wei Ya E0007 chassis has now been fixed and checked. There is a hum from flyback when on and the tube has a faint orange glow at back.
The games board is attached and working, but still NO sign of any picture or anything on monitor.
Any ideas for a layman.
Cheers
Ken Layton
  • Guru
  • Technician
Re: Wei Ya E0007 chassis working (checked), but still blank screen
« Reply #1 on: June 13, 2007, 09:52:56 am »
Screen control turned up?
littlemave
« Reply #2 on: June 14, 2007, 12:14:01 am »
Screen control on Flyback turned right up, but nothing!
grantspain
« Reply #3 on: June 14, 2007, 02:42:46 am »
double check you have all the plugs connected,specially the earth lead to the neck card from the tube braid-mind you you should still get some kind of picture
the only time i have had a monitor power up with heaters but not produce any kind of picture was on a tatung chassis and that was down to the video decoder ic on the neck but i am not familiar with your chassis so to say its the same fault would be a wild guess
 you say the chassis has been repaired and checked,is this by a professional repair company?the reason i ask is that if the chassis did check out ok with them then maybe you should look towards things like a bent pin on the neck-something that is unique to your setup
littlemave
« Reply #4 on: June 14, 2007, 05:57:17 am »
Thanks Grant.
Have double checked all connections (all ok).
Jomac in OZ serviced and had the chassis up and running well.
All pins into neck board good.
Jomac said (i may not of remembered this correctly) but if the video signal from the board is not getting to chassis then some tubes have auto cutout/shutdown. Have you heard of this? If so how do I check this?
Also they said the Vaccum (i think it was) may have gone fron tube, so no way to fix.
Cheers
grantspain
« Reply #5 on: June 14, 2007, 08:11:30 am »
not come across a tube shutdown before,the one thing i would really check is the remote adjustments board-did you send that to joey as well.
i know on hantarex polo2 if the adjustment board is disconnected or plugged in wrong then you don't get a picture although you get chassis activity,now whether this is the case with your chassis i don't know but its something to look at
Kevin Mullins
    • Me on Myspace
« Reply #6 on: June 14, 2007, 07:15:12 pm »
You have said it has a hum from the flyback.... but do you get the High Voltage crackle when you turn it on?
If you turn the SCREEN voltage up you should still be able to make the screen turn brighter even if there is no game attached at all. (unless Joey is right on this model about the chassis shutdown) (good guy too by the way)
Can you take a pic of your video connection to the monitor?
Is the ground on that connection there?
Have you tried this game on any other monitors?
littlemave
« Reply #7 on: June 14, 2007, 10:44:14 pm »
Thanks Kevin. Does not seem to be much of a crackle as normal TV on switch on. High voltage turned right up. Not sure about the ground. The board/tube/chassis are original ones in cabinet (gottlieb Raiden 2 1995) Attached pics.
Cheers
SirPeale
  • Green Mountain Man
« Reply #8 on: June 16, 2007, 06:56:07 am »
Have you tried another video signal source, to rule out that your monitor is working fine, and your board is shot?
littlemave
« Reply #9 on: June 16, 2007, 06:22:56 pm »
Thanks. Only have the one machine. Is there any other way of testing the video signal?
Cheers
grantspain
« Reply #10 on: June 16, 2007, 06:25:58 pm »
have you metered the monitor input voltage yet?
littlemave
« Reply #11 on: June 17, 2007, 04:16:57 am »
Is that the voltage from the transformer to the Chassis?
Cheers
grantspain
« Reply #12 on: June 17, 2007, 04:55:50 am »
Cheers
yep
Ken Layton
  • Guru
  • Technician
« Reply #13 on: June 18, 2007, 12:02:20 pm »
If Jomac checked it out and it worked for him then the problem lies with either your tube/yoke or your gameboard/cabinet wiring.
