Author Topic: Need a vertical layout for MaLa  (Read 2944 times)
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« on: June 11, 2007, 04:39:35 am »
Hoping someone can help.
I'm after a vertical layout for MaLa, something along the lines of Game Creatures "blue" would be the ultimate!! Can't find much out there, and don't have the skills to do one myself.
Can someone help me?
Cheers
loadman
  • Moderator
    • MaLa
Re: Need a vertical layout for MaLa
« Reply #1 on: June 11, 2007, 05:20:54 am »
I have not got the skills either...
Keep in mind you can convert existing mamewah layouts if you want...
The problem is still that mamewah does not use vertical layouts but you may be able to change soem to your liking  :dunno
Converter:
http://mala.arcadezentrum.com/easytrack.php?id=4
sega_mad
« Reply #2 on: June 11, 2007, 04:33:47 pm »
Thanks Loadman,
I had found that converter also, but like you say, MameWah doesn't really do any verticals.
Hoping someone can help??
