Author Topic: Hantarex Polostar + ArcadeVGA problem  (Read 1614 times)
ipaqlinux48
  • Last login:June 07, 2007, 04:03:35 pm
  • I'm a newbie
« on: June 07, 2007, 04:04:15 pm »
Hi,
I've a small problem with my tri-synch Hantarex Polostar monitor. Each time I play a game I've to use the pot-meters to "calibrate" the monitor so that the display is centered correctly. For instance, for some resolutions I've to decrement the vertical height, but for other resolutions I've to increment it.
Is there a solution for this problem?
The more you know, the less you know!
grantspain
Re: Hantarex Polostar + ArcadeVGA problem
« Reply #1 on: June 07, 2007, 04:51:04 pm »
the polostar is a analogue monitor which will not save your settings,so if you change resolutions you will need to manually adjust it-so in other words sorry there is no solution unless you swap it for a digital monitor.
contact hantarex tech dept at www.hantarex.co.uk to see if there is any way around this
