Author Topic: 17" LCD hp f1703 problem  (Read 2615 times)
« on: June 02, 2007, 11:45:07 am »
Did some googling, found out this monitor came fairly unreliable... but this seems to be a different problem than most are getting.  All I get is a white screen, well lit, evenly lit, but no response to any of the menu buttons.  Video source is confirmed good on another monitor.  I'm assuming that means the backlight is good... any other ideas?  LCDs are new to me.
SirPeale
  • Green Mountain Man
Re: 17" LCD hp f1703 problem
« Reply #1 on: June 02, 2007, 01:16:10 pm »
Check the power supply for bloated caps.  I found an LCD recently that wouldn't power up, and all the caps on the power supply are bloated.  I'll replace them when I have enough for an order.
grantspain
« Reply #2 on: June 02, 2007, 02:24:36 pm »
do you get menu options,if so then its whatever i/c does the video decoding-if you don't then i would say the processor
« Reply #3 on: June 03, 2007, 10:55:44 am »
Nope, no response to any of the front buttons other than power, which now that I have it apart, I can see is on a different PCB than the menu buttons.  The menu buttons are on one little PCB, the power button on its own.
EDIT:  just looked, the two boards are daisy chained.  That is helpful.   :banghead:
« Last Edit: June 03, 2007, 11:06:34 am by ChadTower »
BobA
  • What Me Worry?
« Reply #4 on: June 03, 2007, 02:38:44 pm »
If you have another power source give it a go.   The f1703 problems were caused by a poorly performing power brick.   It cculd also be your problem although the symtoms are different.  A bad power source can give many different problems.
grantspain
« Reply #5 on: June 03, 2007, 02:43:35 pm »
good call bob,i have had a problem similar caused by a bad psu but i did get some kind of pic now and then
« Reply #6 on: June 03, 2007, 04:51:59 pm »
I tested the PSU with no load... 12.2v coming through rated at 12v.  So at least with no load it's good.  I can hear it whine a little when it's really quiet, though.  Think it's possible that it just sucks under load?
This monitor apparently had all kinds of problems with bad solder joints on the power board.  I've reflowed and added some solder to most of the potential trouble spots with no change.  I'm going to do the same on the video board to see if that helps.
grantspain
« Reply #7 on: June 03, 2007, 05:14:25 pm »
the whine noise is what i had on my faulty psu,when this occurred i just got a blank lit screen,but it was very intermittent.in the end i just got a new psu from ebay for a few quid and its been great since
« Reply #8 on: June 04, 2007, 10:21:28 am »
Noted.  I'll seek out a new power supply.
EDIT:  link to the part in the HP store.  Not available.  WTF.
« Last Edit: June 04, 2007, 11:31:06 am by ChadTower »
« Reply #9 on: June 04, 2007, 11:32:41 pm »
Okay, I reflowed all headers on all boards, all of the inductors, a ton of random ---steaming pile of meadow muffin---... no difference.  I did order a power supply module off ebay.  If that doesn't work, I'm pretty much out of ideas.
« Reply #10 on: June 05, 2007, 02:58:59 pm »
Got the service manual... has all these specific pins and such to check, I can't find any of these components.  Dammit.
« Reply #11 on: June 11, 2007, 07:08:41 pm »
New power supply changes nothing... guess it's just dead beyond my ability.  Dammit.
